Oil & Fuel What type
   / What type #2
Any upper cylinder lube should work to keep the the valve stems and valve guides from seizing up.
My best guess 2 cycle oil would be the cheapest to add to the gas.
   / What type
Thanks i just bought it has 640 hours the old guy i bought it from told me he used recreational gas never heard of it it's a 1968 one owner. Would you have any idea how much to five gallons gas.
   / What type #4
Good find...I have a '67 that when I found it it had less than 600 hours on it...it now has over 900...be prepared to replace some things, like a water pump and have your generator checked out...I use 15-40 diesel oil...also be prepared to replace your rear tires...sooner of later....good luck! BobG in Va
   / What type
Thanks Bob how much oil to five gallons gas
   / What type #6
Youper....you may have misunderstood me...I use 15-40 diesel oil in the CRANKCASE... I don't add oil to the gasoline...I'm not sure what recreational gas is either...I've put a little residual chainsaw gas (40 to 1 mix) to a tractor fuel tank once in a while when I mix up a new batch for the saws, but I don't add any, any other time...its an overhead valve engine...plenty of oil gets up there by itself...If you haven't checked it also check out the anti-freeze in the radiator..you may want to replace it...since you don't know if the other guy ever did...
   / What type #8
Guys, I do not know about recreational gas, but I buy alcohol free gas at Farmers Supply whenever I can. If you are near my age you will recall using #2 Permatex as gasket sealer, or the more liquid aviation form-a-gasket version. You will recall that it stood up to fuel and oil, but you got it off your hands by using alcohol. In addition to dissolving some gasket sealers, alcohol attacks some seal materials in older engines. At my saw shop, they say 95% of the engine problems they see on chainsaws are due to modern fuel. So with my mowers, saws, generators, brushcutters, etc. I want alcohol free fuel. That definitely goes for my 1959 MF 204.
I really cannot comment about the absence of tetraethyl lead, but we are talking about low compression, low rpm tractor engines. And we are using much better engine oil than was available 50 or 60 years ago. It would be worth researching.
Year: 2017 Make: Mitsubishi Model: Outlander Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A56859)
Year: 2017 Make...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Deere 333G (A53317)
Deere 333G (A53317)
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
