Mainline Mountaineer II REV1500, parts and/or diagrams?
   / Mainline Mountaineer II REV1500, parts and/or diagrams? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I was given a machine that (per the stickers on it) is a Mainline Mountaineer II REV 1500. It was reportedly having clutch issues and the guy I got it from removed the transmission top cover plate/handlebars to look for the clutch.
It has an Acme 330WB engine with a rope recoil type starter.
Are any parts still available for this tractor (I need the splined coupling to connect the power head to the PTO)? Anyone know where I can find a parts diagram?
My parents had a BCS for years (I think it was a Harvester 718, it had an 8HP Kohler on it and they bought it in 1996), should the clutch in this Mainline be similar to the cone clutch that was on that machine?
Pictures:
IMG_20180702_184704.jpg IMG_20180702_184751.jpg IMG_20180702_184616.jpg IMG_20180702_184612.jpg
Thanks
Aaron Z
I'm pretty sure Joel at this place can fix you up, he knows his stuff and can get you going.
Earth Tools
I emailed them, they said that they only handle Acme engine parts and that I would need to contact "Mainline of North America" at 614-361-5343 as they would have what parts are available.
Aaron Z
I pulled the engine off today and disassembled the clutch. It is not a cone clutch, it is a flat plate clutch with a double sided friction disc.
This is the rear clutch disc and its side of the friction disc:
This is the front clutch disc and its side of the friction disc:
Side of the clutch:
This is the pilot bearing and throwout bearing:
This is the clutch as it is mounted to the engine:
This is looking into the clutch when it's mounted to the engine, this is where these throw out bearing gear and pilot bearing end up:
Aaron Z
   / Mainline Mountaineer II REV1500, parts and/or diagrams? #5
Glad you found a contact for parts, if I remember correctly, Mainline and BCS were associated at one time, Mainline did two wheel tractors and BCS made mowers, they combined somehow. I don't remember exactly, but is some interesting history.
   / Mainline Mountaineer II REV1500, parts and/or diagrams? #6
Owner's manuals and parts diagrams as well as replacement parts for the Mainline 1500 series tractor and the Acme engine are available by making a request for them at mainline_na@hotmail.com or calling Paul at 614-361-5343. Mainline of North America was the original BCS distributor in the U.S. and later distributed tractors made by SEP and Goldoni.
Yes, I think I talked to Paul and he sent me a exploded parts diagram.
Tiller is still sitting in the corner of the shop. Haven't had time to dig into it.
Aaron Z
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
