2538 Oil leak not an oil leak
   / 2538 Oil leak not an oil leak #1
millsan1
Gold Member
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
My 2538 was puking a bit of oil when sitting or running or basically existing.
I had a bunch of chores to do with it, so I couldn't troubleshoot. So I just kept feeding a bit of oil in every couple hours.
When I finally had time to trace down the leak, it was not a leak, really. The oil filter had semi unspun and was weeping around the oring. I have never had a filter back off like this on any vehicle, ever. Weird. Tightened it back up and all is well.
   / 2538 Oil leak not an oil leak #2
Make sure if you are the one changing the oil filter, always put some oil on that rubber gasket then snug it up.
2021 Vermeer Wood Chipper (A51573)
2021 Vermeer Wood...
378812 (A51573)
378812 (A51573)
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
UNUSED GREAT BEAR FORKLIFT JIB (A51248)
UNUSED GREAT BEAR...
