Tire Selection Turf or Industrial tires
   / Turf or Industrial tires #1
Dsldoc
Green Forest, AR
Massey Ferguson GC1705
Hello all,
Another newbie here posting for the first time. While I have considerable experience with mechanical things(30 yrs as diesel tech) I don't have a lot of tractor experience. I an going to buy a SCUT in the next couple of weeks. I will be using it mostly for loader work and snow removal. I am trying to decide if industrial tires or turfs would be better. I realize that it is probably a trade off loosing some thing either way. I have heard that turfs are better on snow and ice but wondering if it is that much of a difference, or maybe just go with Ind tires and chains if needed. Any thoughts would be appreciated.
   / Turf or Industrial tires #2
This is a common discussion, so you'll find a lot of feedback in the "Similar Threads" section down at the bottom of this page.
Thank you Ford850,
This helps I think I will just go with R4's and chain up if I need to. I will probably do more loader work in the summer than I will snow removal in winter.
   / Turf or Industrial tires #4
There's a lot of factors that determine what type of "traction" one will get on a given surface.
....but one factor that usually increases traction is weight.
   / Turf or Industrial tires #5
If you go R4's may consider loaded rear tires,also check to see if you need wheel spacers using rear chains on R4's.
   / Turf or Industrial tires #6
R4's suck in the snow (and mud) - treads fill quick and you're done! Chains are heavy to install and hard on the driveways. I went with R1's and never looked back...don't need chains. add as much weight as you can to your tractor when pushing snow - front & back.
   / Turf or Industrial tires #7
R1's(Ag) are my choice,next would be Turf's ,then R4.Our tractors are used for snow removal and dirt work.My BIL has a L3300 set up with Turfs and does really well with it.R4's will have more weight rating but don't do well when it gets slick.
   / Turf or Industrial tires #8
Dsldoc
:welcome: to TBN if given a chose i would choose turfs and add snow chains if needed.
   / Turf or Industrial tires #9
Dsldoc
:thumbsup:
R4's are a pain in the butt to put chains on and they don't like mud and snow very well.
Think of truff's as mud/snow tires
Thanks for all the advice. Lots to think about and decide - what tractor to buy, what tires to put on it, etc, etc.
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
