SHUTTLE SHIFT, REDUCE POWER first?
   / SHUTTLE SHIFT, REDUCE POWER first? #1
geekwithoutacause
MF1240
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?
Sorry if this is a dumb question.
   / SHUTTLE SHIFT, REDUCE POWER first? #2
I reduce speed, not power on our M8540, no question is dumb, these things are expensive.
   / SHUTTLE SHIFT, REDUCE POWER first? #3
:welcome:
To TBN GeekWOAC. You have come to the right place to get answers.
Yes, I do stop the tractor when going from forward to reverse and back to forward... But you don't lower the rpm's before you operate the shuttle valve? The original manual states that.?
   / SHUTTLE SHIFT, REDUCE POWER first? #5
I just reduce speed to almost a stop before changing directions . I very seldom run at a high rpm , if I was I would reduce rpm some along with speed .
   / SHUTTLE SHIFT, REDUCE POWER first? #6
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?.
I do.
I throttle down before forward/reversing. That's what the foot throttle is for.
(my tractor is not a power reverser. Shuttle with a dry clutch)
   / SHUTTLE SHIFT, REDUCE POWER first? #7
I do 90% of my work at idle or just above. If I'm operating at PTO speed I use the foot clutch in conjunction with the hand shuttle.
Welcome to TBN.
So when I am moving dirtpiles, is it easier to use the footpedal ?
Thanks for the comments.
   / SHUTTLE SHIFT, REDUCE POWER first? #9
Not if I am running a bush hog, I have areas on levies and hills where frequent changes in directions, so I leave it at 540 RPM. I also did our Case CX80 with synchro shuttle.
When our M8540 was delivered I specifically asked this as the M8540 has a hydraulic clutch. Moving dirt, grapple, I use the foot pedal o vary RPM.
   / SHUTTLE SHIFT, REDUCE POWER first? #10
ABSOLUTELY! That's my main use for my 4310, a loader tractor. It has the powerReverser 12X12 trans. I only touch the clutch once when i start it; everything else is done with the foot throttle and shuttle. I usually give it 1 second in neutral when switching directions. Hope this helps!
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
23013 (A55787)
23013 (A55787)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
