Rewire ROPS led's to headlight wires?
   / Rewire ROPS led's to headlight wires? #1
prof fate
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
Got a new tractor last month, daylight is long this time of year so I've not gotten around to installing the ROPS lighting I'll need for fall/winter.
First tractor with a loader - headlights are damned near useless unless you put the bucket way low (in the dark in a pasture? no thanks) or way up high (slightly more practical..only just).
So - instead of all sorts of wiring, relays, switch placement etc - why can't I just unplug the headlights and tap into the harness there, run the wires back and up the ROPS?
   / Rewire ROPS led's to headlight wires? #2
Check your wiring first carefully.
Many smaller Kubotas came with a plug under the back seat for optional lighting, you might have a easily accessible plug there.
Oh yeah!
The delivery tech showed me that..said it was wired into the headlights..so yeah!!!
THANKS!
   / Rewire ROPS led's to headlight wires? #4
Might want to separate the Toro from the Kioti, in your 'tractor' list; we Kioti guys don't need people thinking Kiotis are associated with Toro. There's already enough confusion about the orange tractors...
You're right, with a FEL on these tractors the headlights just serve to annoy!:smiley_aafz:
Otherwise, how do you like your Kioti?
   / Rewire ROPS led's to headlight wires? #5
Might want to separate the Toro from the Kioti, in your 'tractor' list; we Kioti guys don't need people thinking Kiotis are associated with Toro. There's already enough confusion about the orange tractors...?
Only you would have a problem with this, most of us could care less what others think.
   / Rewire ROPS led's to headlight wires? #6
I don't have a problem with it; seems maybe you do. What you mean to say is: most of us couldn't care less what others think. So continue to care less until you don't care at all. Was I speaking to you? Are you the OP now? I made a suggestion to the OP, if you don't like it, ignore it, especially if you care so little...
   / Rewire ROPS led's to headlight wires? #7
LED's don't pull that much current. Not like standard bulbs do for the light output they put out. I wonder if the headlight bulbs up front could be replaced with LED drop in's and then run a wire from the headlights to the ROPS for more LED's. Need to add up amperage, but depending what is bought... the amperage may be about the same with more light output. Now you got me to thinking. I have a Kubota L3830 that has a green hot plug under the seat, but I think upgrading to LED's up front and on the ROPS would be a better way to go and they would be on the same switched circuit. If the green hot plug is wired into the light switch that may be even better. Now I need to check. Opinions?
   / Rewire ROPS led's to headlight wires? #8
I checked the green plug under the seat and the power comes on when the ignition switch is turned on, and not connected with the light switch. For me, simply running a wire from the lights to the ROPS would be best.
   / Rewire ROPS led's to headlight wires? #9
I unplugged my headlight harness and ran my front LED lights to the low beams on the headlight switch and the rear LED to the high beams. Didn't even have to cut the factory plug off. A standard extension cord plugged into the harness and I ran the extension cord to the LEDs.
   / Rewire ROPS led's to headlight wires? #10
That's a brilliant way to do it! Did you use a 3 prong ext. cord or just a 2 prong, and both sides or only one side of the headlight plugs? Did you split the one side to high and low or otherwise? Do you have any pics of where you mounted the front LEDs, etc?
TIA,
CM
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
KARAVAN S/A BOAT TRAILER (A52708)
KARAVAN S/A BOAT...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
CENTURY 1000 GALLON SPRAYER (A52708)
CENTURY 1000...
