TYM 394 HST dash went out...
   / TYM 394 HST dash went out... #1
The Chairman
Member
TYM
I have very few hours on this three-month-old tractor and the dash went out. No tach, no fuel gauge. The idiot lights come on when I first crank it, so not everything is dead... just the graphics. Where are the fuses and why can't I get my hood to pop?
   / TYM 394 HST dash went out... #2
Pull the hood release harder. The fuse is in a little box behind instrument panel.
   / TYM 394 HST dash went out... #3
This is from T293 manual Screenshot_20180711-215632_Hancom%20Office%20Editor.jpeg
   / TYM 394 HST dash went out... #4
TYM had some issues with the dashes going out. I believe they fixed the issue. I think you need a new one.
Thanks! I've been distracted with other chores, but this is high on my to-do list.
   / TYM 394 HST dash went out... #6
it should still be under warranty, so you should let your dealer fix it with the update, so it don't happen again..
   / TYM 394 HST dash went out... #7
Do I understand this thread right, my dash lights only light up with all of the information just when I start it but as soon as it is running they immediately all go out -should there be icons lit so you can see what is going on when it is running?
   / TYM 394 HST dash went out... #8
My mahindra 2538 is the same tractor and my lights all go out when running.
   / TYM 394 HST dash went out... #9
My hood release also sucks . if it gets dirt and crud in there it wont allow the lever to move over far enough. i tried lube and that made it worse now i keep it dry and blow it out with air and it opens good now.
   / TYM 394 HST dash went out... #10
I just had the same thing happen with a Cabelas LM36/T354 with 50 hours on it looks like I will be replacing the panel..
2003 McCormick XTX 185 XtraSpeed Tractor (A57024)
2003 McCormick XTX...
VOLVO DD120B DBL DRUM ROLLER (A52707)
VOLVO DD120B DBL...
2005 MACK TRI AXLE DUMP TRUCK (A57192)
2005 MACK TRI AXLE...
1831 (A57192)
1831 (A57192)
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
