lever to raise/lower 3-point hitch
   / lever to raise/lower 3-point hitch #1
4tillingdirt
nc
N/A
I know LS has this lever on the rear on their XR series open station, but do any other compacts have this like TYM554, RK55?
   / lever to raise/lower 3-point hitch #2
John Deere 4R has an option to raise/lower the three point at the rear.
   / lever to raise/lower 3-point hitch #3
I wish my M6040 had a toggle switch on the back of the rear fender. I have an 8 foot chunk of quarter round molding with a shoe lace tied into a loop on one end. Tractor running - slip loop over 3-point lift lever - go out back - push/pull molding - raise/lower 3-point lower arms. Rube Goldberg/Mickey Mouse - but it does work and saves a lot of time and trips making adjustments.
   / lever to raise/lower 3-point hitch #4
Kioti NX and the new DK series has the rear lever,
I wish it was a standard on any newer tractor
   / lever to raise/lower 3-point hitch #5
The Kioti RX7320 has a mechanical lever for raising and lowering the 3PT when standing at the rear of the tractor.
   / lever to raise/lower 3-point hitch #6
My 6530 has that option and that was the item which first got my attention when shopping for a cab tractor back in 2007 and as a result, after shopping all it's other amenities sold me on the product.
For a guy who farms alone, that sir is indispensable and well worth your attention. Telescoping tips another gotta have. And 3rd, tube-pin lift arm stabilizers. If you are considering another badge, call a dealer and ask; if that's your only recourse.
   / lever to raise/lower 3-point hitch #7
When Dad and I were tractor shopping I thought that would be the worlds greatest feature after having spent several years fighting to get things hooked up to our old 8N Ford.
The CK Series Kioti we ended up with did not have said feature and I was in the process of trying to figure out how to rig something when I got a wild hair (and a 25% off coupon) and bought the Cat I quick Hitch from Harbor Freight.
All of our older (antique) equipment has gone under the torch and welder to now be "QH Compatible" and the only new piece I've bough was likewise compatible. Now I only get off the tractor to hook / unhook the PTO when I use the rotary cutter, anything else I never leave the seat.
Given you're looking at a higher HP & Cat rating than we are, a QH might not be in your budget, but just some food for thought.
   / lever to raise/lower 3-point hitch #8
My NX has it and is very useful. I can't remember from looking at the Kioti CK3510SE if that was included with the SE upgrades. The telescopic arms were and those give a little up/down play as well.
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
