Ford 1715 side link.
   / Ford 1715 side link. #1
3 Horse Ranch
Tonasket, WA
NH B50H Cab, Ford 1715, Poulan Pro 46
The adjustable side link on my tractor is worn out. The threads on bottom and cemter sections are barely holding and it often slips a little when I hit a bump. I've looked at replacing the whole thing but the cost was close to $300, which is highway robbery for such a simple part. (It's basically a small top link)
I purchased what I thought was a replacement for $35 but the ball hole is 3/4 but my tractor has. 7/8s pin. The two solutions I can think of are pressing out the 7/8s pin and installing a 3/4 pin or finding a shop that will cut the ball end off both and weld the 7/8s ball end on to the replacement link. Pressing out the pin will require removing the lifting arm from the splins and finding a shop to press the pin out. I am leaning towards the cut and weld solution.
My absolute first choice would be to buy a replacement that fits, either aftermarket or used at a reasonable price. I sire would like to find a source if anyone knows of one. Or if anyone jas a better solution, I'd lile to hear that also.
   / Ford 1715 side link. #2
I bought a complete aftermarket replacement adjustable side link (very reasonable) for my Ford 1920, but mine does not have the ball ends that you describe.
I thought all these Shibaura compacts had essentially the same side link system.
Apparently not!
Apparently not!
I looked at the parts diagrams at Messicks and it appears that the 1715 and a few others have that ball type side link. Other manufacturers use the ball link, but use what is apparently the standardized 3/4" size.
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2016 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2016 CANYCOM SC75...
2005 MGL. ENGINEERING 7436 CONVEYOR (A53426)
2005 MGL...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
Tires (A50322)
Tires (A50322)
