Have I Ruined my Ford 8n Engine?
   / Have I Ruined my Ford 8n Engine? #1
jackbnimble
san angelo texas
8n
I have been trying to get my 8n working by replacing carb, new distributor, plugs etc. Will start, run for a few minutes then die. Started this morning. It immediately went to max rpm, backed off, began to sputter, ran rough then died. I am wondering if racing engine cold harmed internals of engine etc. I am at my wits end trying to get this tractor to run acceptably well.
   / Have I Ruined my Ford 8n Engine? #2
Sounds like a fuel problem. Unhook the line at the carb and see if you have good fuel flow from the tank to the carb since you replaced the carb. I wouldn't think you hurt the engine this morning.
   / Have I Ruined my Ford 8n Engine? #3
Ford 8N entered the market in 1938, so your tractor is nearly 80 years old.
Have you done a compression check so you have an idea of the general condition of the engine?
I doubt you damaged the engine this morning.
   / Have I Ruined my Ford 8n Engine? #4
Disconnect fuel line then turn fuel on and drain into bucket awhile. Make sure fuel stream remains constant and strong. Sounds like you have a fuel delivery issue to carb.
Also make sure new carb is set to factory specs.
   / Have I Ruined my Ford 8n Engine? #5
Close but not quite.
The 9N first came out in 1939.
The 2N in 1942.
The 8Ns came out in late 1947 but were considered a 48 model.
   / Have I Ruined my Ford 8n Engine? #6
Do you still have fuel glass and filter screen? Check it because slow flow makes all the difference. Sounds like bowl is filling then not keeping up with use.
   / Have I Ruined my Ford 8n Engine? #7
on some old carburetors there is a in line screen under the brass fuel inlet in the carburetor, take out he brass fitting and there may be a small cylindrical screen under it,
   / Have I Ruined my Ford 8n Engine? #8
Crickets:jaded:
   / Have I Ruined my Ford 8n Engine? #9
I agree with the others on this sounding like a fuel / carb issue.
Ignition is at least marginal or better if she is starting up and running briefly.
Swict 66" Bucket (A50121)
Swict 66" Bucket...
2014 Chevrolet Impala Limited (A50120)
2014 Chevrolet...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
48" Pallet Forks  (A52384)
48" Pallet Forks...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2010 GMC Acadia SL SUV (A50324)
2010 GMC Acadia SL...
