oosik
Epic Contributor
Rutman - I think people are taking your guess of 30 to 35 degrees as fact. Fact is - if a portion of your driveway IS 35 degrees - then you will need something other than a tractor to maintain that portion. Anyhow - one of these days you can accurately measure and know what that portion is.
Personally - I would recommend a 40 hp or larger Kioti with a heavy rear blade and FEL with bucket.
Jeff brings up an excellent point - that I experienced with my new M6040 back in 2009. I should not have tried backing into one of my carport stalls - even with the ROPS folded. The tractor DID go in the stall - I DID replace the broken head board. Fortunately it was only a 1 x 8 facia board - so no damage to anything other than my pride and the board.
Another thing to consider - with proper maintenance your tractor can be expected to last a life time. Tractor purchase is not like purchasing a new pickup in that 25 years from the date of purchase you can still be using the original tractor. Chances are - you might have gone thru two or three new pickups.
I only traded my brand new 1982 tractor in for my current tractor after 27 years of use. And - by the way - I was given every cent that I originally paid in trade-in for my new tractor.
It didn't take me 27 years to realize that I had projects that would require a larger tractor. I just worked around the larger project - taking on and finishing/maintaining the smaller projects until there was little remaining that could be accomplished with the smaller unit.
Plus, I will admit, I like the power, the grunt, the size, the color, the larger implements that go along with my M6040.
So far after nine years with the M6040 the only down side - implements that are the appropriate size for the Kubota are not easily moved by hand. With the Ford 1710 - I could give the implement a pull or a gentile hip thrust and it would be in alignment for connection to the 3-point. Not the case - AT ALL - with these new implements.
Anyhow - sit on as many as you can - test drive what they will allow - do a lot of soul searching. And when you have made your final decision - go one size bigger.
