Venting a 55 gal drum for diesel
   / Venting a 55 gal drum for diesel #1
BeezFun
IL
Kubota B2710
Finally got a 55 gal drum for diesel, I have an electric pump for it. I assume I'll need to vent the drum when I draw out fuel. I'm thinking of just cracking the plug in the 3/4" bung every time I use it, or is there a better way to provide a vent?
   / Venting a 55 gal drum for diesel #2
I just unscrew the small bung aprt way.
   / Venting a 55 gal drum for diesel #3
You say you have an electric pump? what is the gpm rating of the pump?
You might want a vented filter such as goes in a fuel oil tank.
   / Venting a 55 gal drum for diesel #4
I had trouble finding a filtered vent cap for my 55 gallon drum a couple years ago. Anything I saw was over $50 or something if I recall. I just crack the cap & it works fine. Drum starts collapsing if I forget.
   / Venting a 55 gal drum for diesel #5
These are not specified for fuel but do work;
THREADED HYDRAULIC FILLER BREATHERS | Lenz
for the more frugal of us, get a oil filter with 3/4-14 threads (usually 3/4 bst) and a 3/4 pipe nipple, screw together and you have a good filtered breather
Thanks for the suggestions. Pump is 8gal/min. I like the filters on the Lenz page. For now I'll just crack the 3/4" plug but I'll get one of those filter/breathers. That's a good way to keep the bugs out. I was thinking of making a U out of pipe and stuffing it with steel wool, but the filter is nicer.
Turns out the fitting that threads into the barrel bung has shallow flats machined on the sides, so that should provide enough make up air when I use the pump.
   / Venting a 55 gal drum for diesel #9
That's a great idea if the check valve allows it to vent.
I purchased some filtered air compressor mufflers off ebay that were advertised as 3/4 but turned out to be 1/2" NPT. I used a 1/2" to 3/4" NPT PVC bushing. My drums are stored under a shed. So far I haven't had any problems with condensation or anything by leaving them vented. I went back and forth about that and decided with the temperature changes it would be better to keep them vented than not.
   / Venting a 55 gal drum for diesel #10
The industrial tanks pipe to a filter that looks sort of like an air compressor filter and has two pounds of desiccant. I am planning to use kitty litter and pvc pipe.
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2006 International 7400 Dump Truck (A47477)
2006 International...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
