What loader model is this? Will it fit on a 135
   / What loader model is this? Will it fit on a 135 #1
Youperman
Sault ste Marie Michigan
135 Massey Ferguson
Screenshot_20180628-144113.jpgView attachment 5
I can't say for sure, but it looks very similar to a MF 102 loader. It's a beast. Runs off a front mounted PTO pump.
Thanks i picked it up for $1,000 i thought it might be a 100 model it was a barn find the guy i bought it from told me it will fit on a 135 or 202
Thanks i picked it up for $1,000 i thought it might be a 100 model it was a barn find the guy i bought it from told me it will fit on a 135 or 202:
   / What loader model is this? Will it fit on a 135 #5
I had a 202 and this photo of yours shows a loader assembly that sure looks like the genuine item. All I can tell you was the loader assembly was heavy and powerful. The tractor was a real workhorse for a gasser in its' day.
   / What loader model is this? Will it fit on a 135 #7
That's the same as my loader, although the controls on mine are on the left side. I believe it is a 102 and Shaeff is correct - it does run off a front pump, and IS a beast. :thumbsup: It's incredibly strong, has two pairs of double-acting cylinders and a mounting frame that reaches right to the rear axle. I hope you got the pump and drive with it, also mine has a huge filter in a casing on the left side. You will need, among other bits, a crankshaft front pulley that the pump drive-shaft can be bolted to.
You will be amazed what it will lift. Mine is on a MF40 industrial, which has 7.50-16 front wheels/tyres and a one-piece square front axle - much stronger for weight-carrying than the agri-spec 3-piece adjustable version such as what is on my '68 MF135. You may have the later version square front axle, but be aware of the weight-carrying capacity of smaller tyres; and DON'T turn them inside out! :eek:
I have normal Dextron ATF auto-trans oil in mine ... I was surprised to find that's one of the oils approved for it! :laughing:
Since you've been savvy enough to buy it, can you post a few more pics? Thanks.
   / What loader model is this? Will it fit on a 135 #8
Will this loader fit an MF20 Industrial?
   / What loader model is this? Will it fit on a 135 #9
Just curious. Did you buy this in Missouri?
   / What loader model is this? Will it fit on a 135 #10
Will this loader fit the MF20 Industrial?
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2022 John Deere Z930M (A57148)
2022 John Deere...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
Sterling AT (A56438)
