MF 135 wheel misaligned
   / MF 135 wheel misaligned #1
Tedemoomaw
Omak WA
MF135
I have a MF 135 with a straight axle, the right front spindle broke and after replacing the spindle the right front is 2-3" toed out. Nothing appears bent. I have ran out of drag link adjustment. Any help would be appreciated.
   / MF 135 wheel misaligned #2
Are you sure you got a spindle for the correct side, it is possible the keyway could be in a different place on the other side of the tractor. The other thing you can do is pull the arm off at the steering box and possibly reposition it to make things work.
I put two different spindles on the previous part# 897236m94 had the same problem as the current spindle on it now part# 508546m92. Can a new key slot be cut in the spindle? On the arm adjustment, is that at the end of drag link?
   / MF 135 wheel misaligned #4
Picture?
PULL BEHIND PADFOOT COMPACTOR (A52707)
PULL BEHIND...
2010 Kubota ZD326 60in Zero Turn Commercial Mower (A55851)
2010 Kubota ZD326...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
UNUSED 1RANCH 1RIF 111.02" X 64.96" WROUGHT IRON (A57193)
UNUSED 1RANCH 1RIF...
TANK MANIFOLD (A55745)
