Ballast Water in tires
   / Water in tires #11
water will rust out your rims!. as far as water freezing, it depends on how much water is in the tires, if there is enough room for expansion, then nothing will be damaged, except for the rusting out rims..
My Dad put straight water in all his tractor tires from the 1940s 8N to the 1970's Ford 9000. None ever had any rust at all on the rims. The tires are all filled (including my LS P7010) with water above the rim so the only oxygen available to rust is what is in the water. Tire rims are painted with good enamel paint inside and out so there is little to no possibility of rusting on the inside.
I think you likely confused the filling of tire with calcium chloride vs water with regard to rust.
As to the OP question, as long as you don't move the tractor when the tires are frozen, there is no chance of damage. Mine have been frozen every winter since I bought the tractor in 2010 and there is no damage. As long as you don't need the tractor during the winter when the water is frozen, water is cheap ballast and doesn't harm anything.
   / Water in tires #12
. . . And it is safe and easy to change the amt of ballast you carry.
I typically carry about a ton of water in the AGs of my 7520.​
   / Water in tires #13
I know this, fluid in tires running very low air pressure to obtain a soft ride doesn't work. I had to go with cast iron wheel weights and forgo the solution.
   / Water in tires
Thanks for all the answers. The tractor won't be moved if tires are frozen.
   / Water in tires #15
I have all 4 AGs on the 7520 about 90% full and it rides pretty well except when I pump the fronts up to 30psi for heavy loader work.
   / Water in tires #16
I run water in my tires, but to be on the safe side I added a couple cans of water pump lube with anti corrosion. Safe for both steel and rubber.
   / Water in tires #18
No prob with that here in MI, guys.
In cold weather we park our tractors with the valve stems up. ;)
   / Water in tires #20
chiefcook, I live near Myrtle Beach SC. We normally don't get below say 25 degrees F, but will drop mid teens. Farming here few years ago was mostly totally not cold weather work and many tractors had water only in the tires. Never heard of it being any issue. Now tires were standard bias belted ag tires and they flex right easy.
2150 (A58376)
2150 (A58376)
2012 RAM 5500 (A58214)
KSI Conveyor (A56436)
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
Onsite begins 8:30am / Online begins 9:30am (A57148)
Onsite begins...
CAT930K (A58214)
CAT930K (A58214)
