Fiber cement siding
   / Fiber cement siding #1
tomplum
Elite Member
PNW
XJ2025H
I've done some searching on the web about differences in fiber cement siding. A couple lawsuits back 5 years or so back, but nothing came to really show a comparison. By me we have Hardie, Certainteed and Nichiha available. We had the last house done with Hardie, but now I see the different brands that come with different prices. Anyone have any PE to offer on this?
   / Fiber cement siding #2
I sided my 12x20 storage shed with Hardie Plank siding. We live in a National Forest so I wanted something that would be somewhat fire resistance and rot free. Its a great product but you have to follow the manufactures installation instructions. It was already factory primed on the front. I always prime any edges after making cuts. Leave a small gap at butt joints. I used the special caulk thats for fiber siding. I only nailed along the top which then gets covered by the next piece. If you have to nail close to a seam then pre drill before nailing, prevents spitting. Yes, it makes dust, but a blade made for fiber siding somewhat reduces the dust. Always wear a respirator when sawing !
   / Fiber cement siding #3
I sided my entire house with Cerenteed Fiber Cement siding. Going on 11 years now and still looks great.
I did make one instillation error by installing the first course against a deck surface on one side of the house. Fiber cement does not like to be wet. I’ve since replaced that course with Azeck. And did so by resawing a Azeck 1X6 with a bandsaw to the same thickness as the cement board. There is a slight difference in surface texture but is neglable when painted. Azeck doesn’t care how wet the environment is.
B. John
   / Fiber cement siding #4
I sided my 2600 sq ft house with Hardie Plank a couple years ago BY MYSELF!!!
Some days 102*, I just turned 70.
My house has metal studs (what a joke!) so I had to install all planks with Hardie Backer Screws.
I used Solo Siders to install and they worked great. I checked EVERY course with a 4' level and they came out perfect.
I sealed every cut with latex paint and put 30 lb felt strips behind every joint.
I cut the whole job with a 4 1/2 grinder and cheap diamond wheel plus a diamond wheel on my old table saw when I needed to rip.
I bought a whole pallet of siding, put it on my trailer and moved it around house plus about 80 more planks.
I had very little waste.
   / Fiber cement siding #5
I'm curious....why the double narrow row above the windows?.........Jack
   / Fiber cement siding #6
I'm helping a friend with the siding on his 12 year old house sided with Hardi Plank
The stuff just rotted off due to snow and splash. (Think deck)
I would never use the stuff in New England. I bet it is fine in the less humid areas.
   / Fiber cement siding #7
The stupid way that the house was built had T1-11 on the bottom and then T1-11 overlapped from the top.
I had to put a 1" X 4" strip across the top of the bottom panel and lap the next course over it.
I could probably paint that strip white to make it less strange looking. ???
   / Fiber cement siding #9
It is more fire resistant than the alternatives. Fire I worry about. Excessive rain has never been a problem.
   / Fiber cement siding #10
What is good in one region, fails in another.
Isn't it nice to have a choice! My own home has vertical board and batten siding. All native sawn.
I like it, and it has weathered to a "deep darkness" that overcomes any need to "repaint" ;-)
2021 CATERPILLAR 259D3 SKID STEER (A52706)
2021 CATERPILLAR...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2015 Ford Focus Hatchback (A55853)
2015 Ford Focus...
Hose Reel (A53424)
Hose Reel (A53424)
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
