Deer alarm or repellent
   / Deer alarm or repellent #11
...I doubt alarms will be effective for more than a few days. They get used to it pretty quickly.;;;
motion sensors connected to a cheapo MP3 player with recorded dogs barking has worked for me...
use a cheap 9V amplifier and a couple of cheap boat speakers...
   / Deer alarm or repellent #12
   / Deer alarm or repellent #13
I use a homemade deer repellent made from eggs, garlic and Tabasco sauce. It works for about 3-4 weeks when the weather is dry, a little less so when there is a lot rain. Stinks a bit when first applied but the deer smell it for a long time.
3 dozen eggs
1 cup Tabasco
Handful of garlic cloves.
Run eggs and garlic in blender to puree the garlic and fully liquify the eggs. Strain the eggs and garlic through a sieve to remove the bigger bits. Add the Tabasco, put in a container with a tight lid and store in a location away from other members of your household for a week or so (I use my greenhouse).
Mix 2:1 with water and spray soon the plants you want to protect.
I also use motion activated sprinklers, anything to make them nervous.
   / Deer alarm or repellent #14
3 dozen eggs
1 cup Tabasco
sounds like a Paul Bunyan omelet...!
   / Deer alarm or repellent #15
Deer can jump a 7 ft fence. They can jump a 4 ft ditch. They can't jump both. Add a second fence. Electric would be perfect. They are very wary of floppy tops too.
Self defence pepper spray doesnt taste good. Sprinkler or light on a motion detector works well. Think to yourself" I am going to shoot and eat that deer." Always makes them scarce for me. Every time.
   / Deer alarm or repellent #16
Good suggestions here. I asked the dimensions of your garden because as another poster said, the deer need a place to land. I make my garden long and not too wide. If necessary you can add a row of stakes and wire (grow beans on it) down the middle, or if your garden is large and square, as another poster said, put it a few feet inside the fence all around. They won't jump in if they can't land clean. This has worked for me for years and I have VERY friendly deer who hang around the yard all the time. Agree also they are wary of floppy tops. I wrap "bird netting" around my t-posts to increase the height to around 7-8 feet and just let it flop around. It's a flimsy barrier but they won't jump it. Repellents work fine on flower beds but won't work on a garden.
   / Deer alarm or repellent #17
Start planning for the deer population to only increase.
Deer and ticks. Tick tubes and treating your clothes with insecticide should start now.
   / Deer alarm or repellent #18
3 dozen eggs
1 cup Tabasco
A lot of people add some dishwashing liquid to this mix to act as a surfactant.
   / Deer alarm or repellent #19
One of my master gardener coworkers recommended this: Amazon.com : Predator Guard Solar Powered Predator Deterrent Light Scares Nocturnal Pest Animals Away, Deer Coyote Raccoon Repellent Devices, Chicken Coop Accessories : Garden & Outdoor
I've tried a sonic generator. Didn't work. Milorganite does not work. Some use motion sensor devices that turn sprinklers on. They work, but you need to design your system so you can turn it off without getting sprayed yourself.
For electric fence, you MUST use 3 lines on 4 foot high poles. You can get teflon poles at Lowes (maybe Home Depot) and TSC. You just step on them to put them into the ground. Place one wire so it's about 2-3" off the ground, just above mowed grass, another at the top and 3rd one in the middle. Anything less, and the hooved rats will go through it. Lots of experience that tells me this.
What really works is that 8 ft high mesh fence. It's expensive, and you have to be inventive to have your entrance points.
Even with electric fence, it's a good idea to bait it when you first put it up. Bait it with pieces of aluminum foil on which you spread some peanut butter. Place foil on top fence wire. You'll generally only need to do it once.
Sprays that are either egg based or blood based work. However, you generally have to reapply after every rain and need to change out periodically.
Ralph
   / Deer alarm or repellent #20
Drink lot of beer and mark your territory with urine.
Seems that that works just fine. Since I prefer scotch I need another solution. LOL!.
UNUSED RAYTREE RMH680 HYD HAMMER (A54757)
UNUSED RAYTREE...
New JMR Skidloader Work Basket (A50775)
New JMR Skidloader...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2013 FORD F150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F150 XL...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
