Cause of 2538 increased idle RPMs to 3000?
   / Cause of 2538 increased idle RPMs to 3000? #1
qwikstart
reno, NV
mahindra 2538
Started engine - rpms at 3000 and not decreasing after suggestions to remedy....battery ok.
Does anyone know what might cause rpms to increase at idle?
I would appreciate any suggestion or advice before last ditch option - hauling in to dealer.
Thanks, Deb
   / Cause of 2538 increased idle RPMs to 3000? #2
Could be your throttle cable has slipped, or gotten stuck.
Check on the left side of the engine, about 1/3 of the way in front of the firewall. You'll see the cable attached to a black plastic arm, that pivots sideways. That's the throttle control. I happened to check mine yesterday, and didn't see (wasn't looking hard) an idle adjustment screw. That's why I suggested to check the stop on the cable. Maybe check where the cable goes thru the firewall as well.
Sorry I couldn't be of more help. I'm sure several of the guys on here will have better ideas for you.
Keep us posted.
Keep us posted.
Thanks for your suggestion!
The thing I didn't mention was that the engine was not functioning as if the "rpm's" were that high - I figure it should be screaming. Yes?
As this is all new to me, I was hesitant to assume that maybe the tachometer needle was off or something similar.
But, after checking through possibilities, I called the dealer.
Result: I am the 4th owner of Mahindra 2538 in my area to report similarly. Tachometer reading affected. Instrument panel needs replacing - under warranty.
Thanks again.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2002 KENL 12 Ft Enclosed Trailer (A50324)
2002 KENL 12 Ft...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
