cary on 7k trailer... real capacity?
   / cary on 7k trailer... real capacity? #1
dave2500
Watchung NJ
ford lgt
Hello,
I know technically a trailer with 2 3500lb axles can only hold about 6k payload...
But im sure that this has a large safety margin built in for hitting holes and loads not loaded right...
Every year i have to go about 100 miles to get coal. i try to get as much as possible,
I normally put 3 tons in the trailer and one in my truck..
It has new "E" rated tires on the trailer *15 inch
Is it safe to put 4 tons in this trailer or would the risk of bending something be too high... weight is distributed almost perfectly
on a side not... if I doesnt hit big holes, obviously not all the time, but how much can a 3500lb axle really take?
I have brakes on both axles
Thank you everyone,
Dave
   / cary on 7k trailer... real capacity? #2
Welcome to TBN.
Please post your location, at least in general, for better answers.
Bruce
   / cary on 7k trailer... real capacity? #3
It's a bad idea to overload the axles intentionally on the truck & trailer. You are going to be overloading things separately, not to mention towing any load behind that much weight in the bed. It's a bad idea, dangerous & illegal.
   / cary on 7k trailer... real capacity? #4
But he might be on a 10mph dirt road in eastern Morocco, for all we know. :)
Bruce
   / cary on 7k trailer... real capacity? #5
Probably not that much. How much does your trailer weigh? It's probably around 2k empty. Thus 7k - 2k = 5k payload
Probably, but it's never a good idea to count on safety margins. They are there for a reason. For example, impact loads (i.e. your pot hole reference) can impose loads that are many times "normal"
   / cary on 7k trailer... real capacity? #6
Bruce
100 miles at 10 mph?
I've seen trailer tongues bent because they were overloaded. What is it for a pickup? A ton in the bed is a pretty good load.
Somewhere on this site is the story of a member who went for a wild ride after suddenly snapping the front straps holding his tractor down causing it to roll backward, losing his tongue weight. He later determined that while he was within the weight rating for the trailer, it had flexed on a bump causing his straps to break.
   / cary on 7k trailer... real capacity? #7
Hello,
Thank you everyone,
Dave
A trailer with two 3500lb. axles will weigh about 2000 lbs. EMPTY!
That leaves 5000 lbs. available for cargo.
4 tons of coal = 8000 lbs, on a trailer rated for 5000 lbs. of cargo.
That is an80% overload!
   / cary on 7k trailer... real capacity? #8
Hello,
Thank you everyone,
Dave
A trailer with two 3500lb. axles will weigh 2000+ lbs. EMPTY!
That leaves less than 5000 lbs. available for cargo.
4 tons of coal = 8000 lbs, on a trailer rated for 5000 lbs. of cargo, towing 100 miles?
That is an 60%+ overload!
And ..... how much bumper hitch tongue weight on a truck already loaded with 2000 lbs. in the bed?
You REALLY think that would be safe?
   / cary on 7k trailer... real capacity? #9
If you factor in a 1000 pound hitch weight and a 2000 pound trailer weight you’re probably fine with 3 tons on the trailer. There’s no way I’d put 4 tons in a 7000 pound trailer.
   / cary on 7k trailer... real capacity? #10
You forgot tongue weight.
7000# trailer - 2000# weight + tongue weight is the actual (legal) carry capacity.
Put 1000# on the tongue and you are fine with your 3 Tino load. But not sure if you are doing that with an additional ton in the bed.
If you have a modern one ton ....put 1000# on the hitch....ton in bed......6k on trailer......yep. that would be fine but that's about the limit.
2017 John Deere 6120E (A53317)
2017 John Deere...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2225 (A58376)
2225 (A58376)
Gorman Rupp 14D52 10 Series Centrifugal S/A Towable Water Pump (A56857)
Gorman Rupp 14D52...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2863 (A58376)
2863 (A58376)
