Kubota KX41H mini excavator problem
   / Kubota KX41H mini excavator problem #1
BertZegers
Gold Member
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
I have a old Kubota KX41H excavator that served me well for years but when I started to use it this morning I did not have hydraulic power on the arm, the left travel track and the auxiliary port. Everything else works fine. Hydraulic oil level is OK. Unfortunately I don't have the work shop manual.
You are right, but I didn't find it, sorry.
The arm, the left track motor and the auxiliary quick coupler did't have pressure. They are all fed by the same one of the three pumps. I was thinking either pump not working or a failure in the main relief valve for this circuit. I found a plug on the valve were a poppet sits under. This was the easiest to get at so I opened it and let a little oil leak out and then put the plug back.
Everything works again.
   / Kubota KX41H mini excavator problem #4
I was not trying to correct you. I was trying to help point you to a very good forum on excavator problems in case you were not aware of it.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Pontiac Car (RUNS)(TITLE) (A50774)
Pontiac Car...
2016 Chevrolet Tahoe 4x4 SUV (A50324)
2016 Chevrolet...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
