2006 Branson 4720i fuel injectors
   / 2006 Branson 4720i fuel injectors #1
LP Ranch
Priest River, Idaho
Branson 4720i
I'm looking to see if there is a comparable fuel injector for the HK12020000a3? They want $115 per injector so I'm hoping someone else might have found an equivalent injector.
Thank you!
   / 2006 Branson 4720i fuel injectors #2
Looking for the same injector. Did you find a cross with Cummings?
   / 2006 Branson 4720i fuel injectors #3
I can rebuild them.. send me an email
   / 2006 Branson 4720i fuel injectors #4
Thank you!
Why are you looking for injectors? How many hours on your machine? What do you use for fuel hygiene/storage and do you use any snake oil additives? If so, what and how much?
I've been running several diesels at a time since back in the '80's and the only injectors I ever bought were part of an overhaul of a '60s vintage JD 96 hp 4020 purchase I made and part of the overhaul of the 3000 when I bought it.
   / 2006 Branson 4720i fuel injectors #5
300 plus hours on machine. Always use fresh diesel from reputable source. Use diesel power service additive. I have 2 other dirsels with never an issue
   / 2006 Branson 4720i fuel injectors #6
Price to rebuild and turn around time?
   / 2006 Branson 4720i fuel injectors #7
Prvt. Msg. sent.. check the "alert" box at the top of the page. {envelope}
   / 2006 Branson 4720i fuel injectors #8
Hmmmm. Rare, and failing at 300 not initially or 5k at that.
44508 (A51692)
44508 (A51692)
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
Electric Forklift Pallet (A50322)
Electric Forklift...
