3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes
   / 3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes #1
dieselscout80
South Carolina
New Holland TC45DA
I want to weld on a new 3pt Lower Lift Arm Weld On Repair Ends, but I want the new ends/balls to have Combination Cat 1 & Cat 2 Holes.
I can find just the socket, but I would prefer the whole weld on end like the first attached picture, but I can't find them in the USA. My google searching may just be faulty.
Combination Ball Socket
   / 3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes #2
Where did you find Picture of end with cat 1/2 holes....
566570d1534175831-3pt-lower-lift-arm-weld-1-lower-link-weld-ball
Picture source would be best place to start...
Dale
Dale
It was on a British site, so that's a no go with shipping and currency conversion.
   / 3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes #4
I welded on the commonly found Cat 2, and just use a bushing. Never seen the combo version you show. The bushings work fine.
   / 3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes #5
Go to a local tractor salvage yard.
I had a Massey Ferguson a long time ago that had it.
   / 3pt Lower Lift Arm Weld On Repair End with Combination Cat 1 & Cat 2 Holes #6
lots of Deere 5xxx series have these as well. Not terribly unusual
I found that indeed John Deere 5XXX series have them and I see pictures of 5105 and 5205 with them, but I am yet to find a weld on repair end for them even on Deere's parts site.
Gas Pump Artwork (A55758)
Gas Pump Artwork...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
2016 PETERBILT PB337 FLATBED TRUCK (A57192)
2016 PETERBILT...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
Yanmar YT359 (A53317)
