Massey 250 Hydraulic Problems
   / Massey 250 Hydraulic Problems #1
adamwhite
MF 250
Thank you for the add. I would like to post a question regarding my Massey 250.
Hydraulics slowly stopped working. I changed the fluid and cleaned the filter (both were very dirty). They hydraulics worked for a few minutes then failed, and the low pressure warning light came on.
I assumed my pumps were bad, so I replaced both the primary and auxiliary pumps. Again, I had pressure for about a minute, then lost it. I'm uncertain where to check next. Seeking advise please. Thank you in advance.
   / Massey 250 Hydraulic Problems #2
You may have a split in one of the steel lines under the top cover...
   / Massey 250 Hydraulic Problems #3
Split in the line or faulty relief valve. Unless the draft control lever is in the wrong position...
Vermeer 5410 Round Baler (A50774)
Vermeer 5410 Round...
KENWORTH VIN - (A50323)
KENWORTH VIN -...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
