Kawasaki Vtwin Not Running Right, Reliably
   / Kawasaki Vtwin Not Running Right, Reliably #11
On my engine, I just pull the signal cable from a coil. If the engine dies, the other one's the problem.
   / Kawasaki Vtwin Not Running Right, Reliably #12
Had a similar issue last spring on the John Deere with the Kawasaki twin. It was the coil. Replaced the bad one and the plugs. Started right up. It was running on one cylinder, no power.
   / Kawasaki Vtwin Not Running Right, Reliably #13
Yep, coil is also a possibility. I'd check air and fuel issues first. Spray down the carb with carb cleaner while it's running at the lower/malfunctioning RPMS and see if it perks up. As I mentioned, it could just be a sticky governor linkage or loose spring, etc....
Kinda fun but no fun to troubleshoot these kind of things. When you finally do find the problem, it makes you feel pretty good! :thumbsup:
   / Kawasaki Vtwin Not Running Right, Reliably #14
Welcome to TBN! :thumbsup:
   / Kawasaki Vtwin Not Running Right, Reliably #15
Pretty easy to check spark on both cylinders. I chased fuel issues first, because that is what it seemed to act like, new filter, carb cleaner, etc. Wasted several hours and bucks. Pulled the plugs and the problem was identified quickly.
How good you feel, when you figure it out, is inversely proportional to what it costs to fix...
   / Kawasaki Vtwin Not Running Right, Reliably #16
How many hours were on your engine when the plugs fouled out?
   / Kawasaki Vtwin Not Running Right, Reliably #17
It was a bad coil. Verified by swapping the coils. One of the plugs was damaged too, probably from backfiring. I suspect the plugs had several years on them.
   / Kawasaki Vtwin Not Running Right, Reliably #18
There's always the situation that the vent on the fuel tank or cap is plugged
   / Kawasaki Vtwin Not Running Right, Reliably #19
There's always the fact that the vent on the fuel cap is malfunctioning also
   / Kawasaki Vtwin Not Running Right, Reliably #20
I'd bet dollars to donuts that
That use to be one of my Daddy's favorite sayings. He passed 50 years ago...sure miss him. Thank you.
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
