new mahindra with no regen?
   / new mahindra with no regen? #1
arits74
dixie ar
ls ,xr4155hc,1942 h farmall,vermeer cx218 mini
saw a local ad for new 33 hp Mahindra with no dpf,no def fluid and no regen.how are they getting around this
   / new mahindra with no regen? #2
Yep. I have one, and there's no dpf, no regen, no nuthin'. Mahindra chose to invest in completely redesigning an engine that could meet Tier IV standards without DPF or regen. I kind of liked that, although many folks say it's no big deal.
The Mahindra mCRD technology is the direct result of a $30 million-dollar investment to redesign and re-engineer our Tier IV Engines for a simple and user-friendly solution. The result - we've created engines that don't utilize a Diesel Particulate Filter (DPF). This means no excess heat or burn off and less complexity for the operator. The Mahindra mCRD Tier IV Engines provide unique advantages: it reduces gas emissions by over 360 tons per year, meets the new Tier IV emissions standards without the need for a DPF, but still allowing you to Push More, Pull More and Lift More.
01MAHINDRA COMMON RAIL DIESEL FUEL INJECTION ENGINE
Delivers higher injection pressure in Common Rail Diesel technology greatly reducing visible engine smoke.
03DIESEL OXIDATION CATALYST (DOC)
The DOC after treatment system does not require any system regeneration. [regen]
Meets emission standards at a lower cost, keeping more money in your pocket.
No DPF filter, therefore no backpressure monitor and filter cleaning, meaning less maintenance required and no expensive filters to replace.
02MULTIPLE INJECTION FOR CLEANER EXHAUST
Multiple injection points mean more efficient fuel combustion for cleaner and greener exhaust emissions.
Provides fuel efficiency.
A significant reduction in NOx and Particulate Matter (PM) emissions.
04HIGH EFFICIENCY POSITIVE CRANKCASE VENTILATION (PCV) TECHNOLOGY
Captures gases from the combustion chamber and cleans them before being released into the environment.
DOES mCRD SAVE YOU TIME & MONEY?
The answer is YES! A DPF left unchecked will collect soot and ash - resulting in damaging or destroying the filter, reduced performance, unwanted repair costs and unscheduled downtime. But not with mCRD; you get better fuel efficiency and lower maintenance costs in a SIMPLE system without the need for DPF. That's the Mahindra Value we provide to get you back into the seat to turn the land you work into the land you love!
   / new mahindra with no regen? #3
New tractors with no DPF or DEF setup FTW!
Massey Ferguson is the same on their 75 HP and under tractors. They use a DOC(instead of a DPF) and a EGR valve setup to help achieve Tier4.
   / new mahindra with no regen? #4
When I was tractor shopping this past winter I found there were several brands that were able to meet Tier IV requirements without needing a DPF. Mahindra was one, New Holland was another. I really liked the New Holland T4.75 for several reasons, one being no DPF, and was all set to order one if the dealer and I could agree on a price. But then a Kubota M7060HDC12 with only 170 hours on it came up for sale locally. Price was thousands less than a new T4.75 so I bought the Kubota. It does have a DPF but that's turned out to be a non-issue. Light comes on in the dash telling me it's going through a regeneration cycle and after 15-20 minutes goes out. No difference in the way the tractor operates during the regeneration process.
   / new mahindra with no regen? #5
Like others have stated they went with a DOC and aggressive EGR to accomplish this. Other brands went this route also. No tractor under 75 hp uses or needs DEF, no matter the system used.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
Towable arrow board (A55973)
Towable arrow...
2021 Deere 333G (A53317)
2021 Deere 333G...
Kubota M5-111 (A53317)
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
