Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure
   / Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure #1
bcribb
Member
Wilmington NC
Farm Trac 390 HST
I'm trying to find out how much pressure my electric fuel lift pump is supposed to have. Its a 390 HST Farm Trac 4 wheel drive tractor.It has a 4 cylinder Mitsubishi engine. My tractor is bogging down under a small load. Fuel line is clear from the pump to the tank. Has a new fuel filter and recently cleaned injectors. The tractor has always had this problem but seems to be worse now. When I pull my rake up a slight incline the engine will bog down and sometimes shut off and then its hard to start back up. Any help on this problem would be greatly appreciated..
   / Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure #2
That does sound like your lift pump isnt pumping enough GPM/psi. Next time it shuts off turn the key so the pump comes on and let it run for about 30 seconds. If it starts right up you need a new lift pump.
Or you could just throw one in anyway. There about $35 from airtex.
   / Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure #3
Really depends on what type of injection pump it has..
IF its the small inline PFR pump that sits down inside its own "cradle" on the engine?? it needs about 10 psi at the inlet.
If its the larger inline pump that bolts up to the engine block & is gear driven.. it needs 25 psi at the inlet to run properly.
IF its the small rotary pump that bolts up to the engine block & is gear driven, it only needs 1-3 psi at the inlet & is usually gravity fed.. but a lot of people put electric pumps on them.
Thanks, I try to figure out which pump I need, 4 lb or 12 lb
   / Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure #5
I just looked at your other post about the solenoid.. You have a PFR pump.. the one that sits down IN the engine block.
Gonna need the 7-12psi.. A 25psi will be WAY to much & you stand the chance of hurting other things.
You have helped me so much and I appreciate it. Where can I get a 7-12 lb pump. Thanks
   / Farm Trac 390 HST 4 cylinder Mitsubishi diesel engine electric fuel pump pressure #7
Aritex, MrGasket, Summit Racing..
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2015 Ford F-550 Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
