Ford 1720 Clutch questions...
   / Ford 1720 Clutch questions... #1
Stangusso
Belmont, NH
Ford 1720
I have a 1989 ish Ford 1720 4x4 with 1300 hours. After sitting for the winter the clutch appeared to be stuck. I depressed and released it very quickly several times and it seemed to come around. About 10 hours of use later I noticed that the clutch pedal didn't seem to return completely, and felt different. Shrtly thereafter, the clutch began to slip. The machine barely moves forward or reverse at this point. Does this mean I have to split the tractor and replace the engine clutch disk, or is there an adjustment of some sort I don't know about? How can I diagnose the issue?
   / Ford 1720 Clutch questions... #2
Does it have som inspection holes in to the clutch?
I haven't found one yet.
   / Ford 1720 Clutch questions... #4
If you have a loader on your 1720 the clutch access/inspection hole should be behind the left FEL mount verticle post.
You will need to remove the FEL to see the hole.
Thank you! I will look tomorrow. I appreciate the direction.
   / Ford 1720 Clutch questions... #6
Did it come with the little block of wood to keep the clutch depressed when not using. My 2120 & 1710 did.
Andy
   / Ford 1720 Clutch questions... #7
Andy
A clutch block can be made from any scrap piece of 2 x 4.
   / Ford 1720 Clutch questions... #8
And I believe the owners manual mentions how to fashion that piece of wood yourself.
Steve
I removed the FEL but don't see any inspection cover. Do I have to remove the horizontal post the FEL was mounted to? Also, do I have to drain the oil to do the inspection?
   / Ford 1720 Clutch questions... #10
"horizontal post" ????
2018 Toro Groundsmaster 7210 Model 30695 72in Zero Turn Mower (A50322)
2018 Toro...
40' CONTAINER (A51244)
2011 Volvo Semi Truck (NOT RUNNING) (A50774)
2011 Volvo Semi...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
