Kubota B7510 HST transmission oil volume
   / Kubota B7510 HST transmission oil volume #1
treeguy99
kubota B7510
so I've just joined this website in an effort to get the right info so I can properly change the transmission oil in my B7510. I've done a ton of reading online. My manual and website info says that the capacity is 15.3 litres. After carefully following instructions on Messicks (best i could find) I can only drain 10.7 litres from it. What am I missing? I removed a plug from the front transmission case, a plug from near the mid PTO and a plug off of each side of the rear axle. I removed both filters and the screen. Don't want to refill it with having left old oil in it.
Scratching my head in Thunder Bay
   / Kubota B7510 HST transmission oil volume #2
Good luck in draining out every hose & cylinder as that's a near impossible task. Just drain all you can out of the transmission housing (sounds like you already have) then refill. A little leftover wont hurt unless it's really contaminated. If it's that contaminated you need to refill, run it a bit, the drain & refill it again. Unless it looks like a milkshake or had something blow up inside it's not going to be that contaminated.
thanks so much for the quick response. I will finish off the job and keep close attention to replacing the same amount as I took out.
for those coming behind me...the screen 26mm nut and filters were tightened at the factory by a gorilla. I had to use extensions on the wrench. Don't use anything but a 26mm socket on the screen nut head. Messicks website was useful as was this.
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
