When the machine hydraulic oil is at operating temperature (ie Hot, not cold), I get a squeal at different
parts of the machine when UNDER LOAD (like going up an aggressive hill I get a squeal in the rear, or just holding the bucket control past the
stop squeals at the lift boom, etc.).
A literature review reveals this could be water or air contamination, both bad. I think it is air.
A couple of potential causes- a leak in the system, or, when I "changed" the hydraulic oil recently I got air in the system when running the machine and the oil reservoir was not full (level below the feed tube.)
Bottom line is that I think the hydraulaic oil needs to be thoroughly removed and replaced. However, there is no drain plug- the resovoir holds a portion of the system oil and the rest is in the lines and devices.
Question- I don't know hydraulics, so how do you get all the oil out of the hoses and devices (pump, valves, etc.)?
Thanks
Thanks
