1991 4630 ford neutral safety switch
   / 1991 4630 ford neutral safety switch #1
rickyb01
Mayflower
1976 Deutz 3006 1962 John Deere 1010
My tractor has started well not starting. Some times it starts and sometimes it doesn't do a thing and then bam it starts. Solenoid is clicking but no juice to starter. I can check the pto switch and have. I think I only have two safety switches and was wondering where the neutral safety switch is and how to access? Thanks Ricky
   / 1991 4630 ford neutral safety switch #2
The switch is internal to the transmission and accessible by removing the shift cover. You can test it by unplugging the wires going to the switch at a connector above the shift cover and checking continuity with a VOM.
   / 1991 4630 ford neutral safety switch #3
Ricky
You references and terminology make no sense what so ever. What solenoid are you talking about?
   / 1991 4630 ford neutral safety switch #4
Ricky
I am guessing the starter solenoid, if it is clicking but not turning over the problem is most likely internal to the starter solenoid, internal to the starter itself, or in one of the large wires going from the battery to the frame or from the battery to the starter solenoid.
Aaron Z
   / 1991 4630 ford neutral safety switch #5
Before going after the solenoid, be certain that your cables are FIRMLY attached at the battery, and that the ground cable is firmly bolted with good contact to the ground. A loose ground connection will give you the sometimes start/sometimes not situation.
   / 1991 4630 ford neutral safety switch #6
The solenoid clicking says that your safety switch is closed allowing power to your solenoid primary winding. Since you hear the click the next question is whether or not it is closing the high current circuit so power will go to your starter.
We used to use a pair of common pliers with the handles placed across the input and output ⅜" copper terminals of the solenoid. Yes it will spark, but if you do that and the starter pops or makes any kind of motion that it wants to move, your hight current contacts in your solenoid are burned out. Time for a new one and be careful that you get one that will work with your safety switch.....that's one that there are 2 small studs on it, isolated from everything else in the solenoid whereby one goes to your safety switch to pickup ground and the other goes up to your key switch for power.
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
FAKE (A52472)
FAKE (A52472)
