Drain tube came loose from crank case.
   / Drain tube came loose from crank case. #1
Vigilant
Instead of the cap coming off the end of the oil drain tube, the tube and cap are now coming loose from the crank case. This is on a John Deere GT275. Can the tube be welded to the crank case? Thanks.
   / Drain tube came loose from crank case. #2
Might be one of the very few times I'd look at JB Weld so it can be removed easily. Too bad you can't have the tube knurled so it will stay in. Is that what they do or are they just pressed in? I had a car that did the same and JB worked.
2005 Kubota ZD21F Zero Turn Mower (A55851)
2005 Kubota ZD21F...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
(APPROX. 20) 4' X...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2016 FREIGHTLINER...
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
2018 New Holland Workmaster 60 4x4 Tractor with Loader (A54865)
2018 New Holland...
