Type of grease used
   / Type of grease used #1
jackhorn01
Mahindra 4540
I have two grease guns, one with marine grease for the boat / trailer and one with general purpose heat resistant grease for my riding lawnmower since it requires it. I have been using the Mystik hi temp grease from Tractor Supply on my tractor that I use on riding lawn mower to avoid having to maintain and keep up with a third grease gun. Is this ok?
   / Type of grease used #2
The only grease I definitely would not use is clay based greases. They do not resist water well. I virtually use a moly base grease on everything, except wheel bearings, even though it is messy. Impossible to wash it from rags and stains my overalls.
Ron
   / Type of grease used #3
Kubota recommends moly supplemented lithium based grease for contemporary tractors.
Mediocre grease applied regularly is better than expensive grease applied infrequently.
   / Type of grease used #4
Kubota recommends moly based grease for contemporary tractors.
Preach it. Grease regularly & worry less about what type of grease you use. Just pick one & stick with it. Some grease types aren't compatible, but that's not a problem if you clean out the old stuff before switching.
I use some of the nasty black molly stuff on everything but wheel bearings myself (have a tub of high temp wheel bearing grease for hand packing wheel bearings). With as hard as it is to get off hands & clothes, you can probably assume its going to stay on the bearings & bushings.
   / Type of grease used #5
I learned of Mystic green when I had a boat. I was using red in everything. Ran some tests on the red vs green and couldn't tell the difference in ability to stay in place in a water environment so I stuck to the red. Red is red as I see it whether it's wallyworld red or TSC red or Mystic red or whomever.
   / Type of grease used #6
It is my understanding the red grease is for high temp applications and not what I will call normal use. Have had two different brand dealers recommend the red high temp for such as blade spindles but not for say linkage. I do use the red high temp on excavator bucket pins for water will not wash it out very easy. The red high temp is too sticky for low temp uses.
   / Type of grease used #7
I read somewhere that Moly is for sliding surfaces, not rolling surfaces as it't too slick for such. I have a tube for that...use a popsickle stick for an applicator and only on sliding surfaces. When I ran sickle bar hay cutters, that's a sliding surface that likes it.
On using red grease for low temp applications, the only thing I can see where that might hurt something is that it may remain too viscous for a ball to roll in a race......I guess that'll just hit me one of these days as I have many bearings on my farm crammed full of it and the way it's been since I can't remember when.
   / Type of grease used #8
Valvoline Moly-Fortified Multi-Purpose Grease Ford : Product Catalog - Valvoline<sup>(R)</sup> Some molly greases are speced for wheel bearings.
   / Type of grease used #9
Not so much fun with a backhoe. I switched to a 5% moly grease that holds and lasts longer than the old 3% product I was using. Not good for wheel bearings.
Last time I did wheel bearings I just bought the travelers waterproof marine stuff from TS. Not sure if it's any good but time will tell.
   / Type of grease used #10
I use whatever is on sale at Tractor Supply. That is typically their Multi-Purpose Lithium or heavier duty rated red high temp grease. I do have some corn head grease for use in gearboxes if needed.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
Miles read : 112,969 (A50323)
Miles read ...
Utility Trailer (A52377)
Utility Trailer...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
2000  INTERNATIONAL 3800 MID SIZE SCHOOL BUS (A54607)
2000...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
