New member - PT-1850 and Montana 5740C
   / New member - PT-1850 and Montana 5740C #1
jkulloa
Kansas City, KS
Power Trac / PT-1850, Kubota BX2670, Steiner 450, Bobcat T300
Hi. I am a new member, but have referenced TBN quite often. I just bought a used PT-1850. It is old (2003), but low hours. It sat outside a while, so will likely have some things come up from time to time.
The steering went out today after four hours of tough brush-hogging. Had to do a bunch of loops to get it straightened out, but finally got it into the barn. I am hoping it is one of the steering cylinders. The steering seemed slow when I began using the machine a few days ago, but I didn't have a frame of reference. Anyone know how to tell which cylinder is the culprit? It seems to turn to the left more readily than to the right.
Anyway, glad to be here!
   / New member - PT-1850 and Montana 5740C #2
:welcome: Thanks for joining!
I'm going to move this thread over to our Power Trac section for you :)
Thanks Catherine!
   / New member - PT-1850 and Montana 5740C #5
Welcome. If I were you I would call Terry at power trac tomorrow he could give you a quick answer Phone 1-800-theyard.
Thanks for the welcomes! Called Terry, and he said I should rebuild both steering cylinders. I ordered the kits and am looking forward to a good project later this week or next!
   / New member - PT-1850 and Montana 5740C #8
Hey Carl, I think he found your tractor's twin!
Welcome aboard, Juan!
Yup. Yup. I think so. Jk if you need advice on how to change them.
Thanks for the offer. Completed the job Friday night. Was not too bad, but one of the end caps was already pretty deformed. I was able to remove it and put it back together nonetheless. I hope it doesn't cause any problems. Maybe I should order a replacement to have on hand just in case.
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
Champion Generator (A54865)
Champion Generator...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
