Enclosed trailer - Is a V-front worth it?
   / Enclosed trailer - Is a V-front worth it? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
On a medium sized trailer (7' x 14' to 18') what per cent fuel savings can one expect?
   / Enclosed trailer - Is a V-front worth it? #2
everywhere i read says they track worse and sway worse..
   / Enclosed trailer - Is a V-front worth it? #3
What are you pulling it with? It might be less a question of fuel savings and more a question of possibility. My last truck was a 2005 GMC 1500 2WD with the 5.3 and 4spd tranny. I forget what gears it had, but it got good mileage so high gears. It would pull a flatbed or car hauler loaded to the max with no problems. I used it to pull machine tools, sometimes up to 10,000lbs. No problem. Then one day my boss asked me if I could pull the company box trailer (little trailer) 300mi to Louisiana because he couldn't find a hotshot available. The load inside was <2,000lbs. First time I had ever pulled a box trailer. My truck did NOT like it one bit. Pulling that flat front down the interstate at 65mph was like trying to pull a parachute. The truck was continually shifting between 3rd and 2nd gear at 65mph and my dash said I was getting 7.5MPG where I normally would get 18-22MPG. I had to stop for fear of destroying my transmission. Had to call my boss and tell him I wasn't able to do what he wanted. He ended up finding a hotshot to meet me and take over. Hotshot was driving a dodge 2500 with a Cummins and I spoke to him afterward and he said his truck pulled it like it wasn't there. It didn't affect his MPG at all. Same MPG as unloaded (nearly 20mpg). As much as it has to do with the gearing and the low end torque of a diesel, I think it had to do with the profile of the truck and the amount of exposed trailer. My GMC factory ride height was pretty low, and the truck was not tall either. It had pretty low cross sectional area for a truck and a low coefficient of drag, and it was designed that way and that's why it got good mileage. That box trailer behind it stuck up 2+ft higher than the cab of the truck and caught all the wind. The dodge truck had a higher ride height and a taller cab. Overall bigger truck, more cross sectional area, and it totally blocked all the wind that would have otherwise hit the trailer. The trailer rode in a nice little sheltered air bubble behind his truck and didn't cause much resistance at all. So for him, it probably wouldn't have mattered at all whether it was flat front or v-front. For me, it wasn't possible to pull the flat front, but it may have been possible to pull a v-front. I don't know; never tried, and I don't have the truck anymore to test it. I have a 2010 GMC Yukon now and I've pulled that very same box trailer with it, with no issues. It has the same 5.3 engine but a 6spd transmission and it has much more cross sectional area. The trailer is mostly hidden behind the yukon.
I say all that to say this; if you've never pulled a box trailer with the truck you are intending to use, maybe you should try it out.
What are you pulling it with?<snip>
A Ford F350 7.3 dually
attachment.php
   / Enclosed trailer - Is a V-front worth it? #5
We had a v nose for 7 years took about five mpg off what it the truck normally got load consisted of three large atvs. Pulled with 2001 dodge 2500 24V diesel
   / Enclosed trailer - Is a V-front worth it? #6
Conservative guesstimate, 2 - 3%.
There are many variables. PU with high topper, or stacked up load bed may "shield" a flat front some, so it depends in part what your baseline is. Look at highway tractors - fleets put nose bubbles on trailers a really long time ago, and have spent the last 10 years or so adding all sorts of aero kit to trailers.
A pro-wrench buddy of mine used to set up trailers around that size to haul race bikes from here to South Carolina. Pulled with an old Ford diesel. He always went with a Vnose. I believe the aerodynamics are a little better - nobody minds burning a little less fuel, but in his case, he mostly liked them for space utilization. A full bubble front would probably be the best for aero, but I haven't seen any in this class in production.
As a race trailer, the V was a nice space to set up shelving to store and organize support supplies...... less of an issue for short term bulk transport, but it depends on what your present and future needs are.
Rgds, D.
   / Enclosed trailer - Is a V-front worth it? #7
So you got worse mileage with V than equivalent flat-front trailer ?
(Not arguing :) , just not sure I'm fully understanding your post.....).
Rgds, D.
   / Enclosed trailer - Is a V-front worth it? #8
I have a 17 F350 diesel 4x4 crew cab. Towed a 7x16 DRW Vnose from Mass to Kentucky empty.. and from KY to Mass with 4K inside of it. Tracking was never any issue and fuel averaged 12.5 down and back. No trailer I’m getting 17.5 with the same truck.
So you got 5mpg less than when running w/o trailer?
<snip>
Thanks, nice clear number.
I have a 17 F350 diesel 4x4 crew cab. Towed a 7x16 DRW Vnose from Mass to Kentucky empty.. and from KY to Mass with 4K inside of it. Tracking was never any issue and fuel averaged 12.5 down and back. No trailer I知 getting 17.5 with the same truck.
Thanks, no trailer I'm getting 15 to 17. Loaded equipment trailer it drops to 10 or 11.
   / Enclosed trailer - Is a V-front worth it? #10
571175d1537122926-enclosed-trailer-v-front-worth-101_0019-jpg
You will notice a little savings with MPG's, not much but you won't know it's behind you with the old 7.3 dually.. I pulled a 20ft V-nose for a few years with my tuned 7.3, it pulled nicely..
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
VERMEER V6500 COMBO TRENCHER (A52708)
VERMEER V6500...
CAT 336E (A58216)
CAT 336E (A58216)
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
