Is it OK to weld closed some drilled holes in my 1960's truck frame?
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #11
Cut an appropriately short section of 7//16 bolt or (1/2”), pound it into the hole and grind flush.
Prime and paint.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #12
As a quick backing for filling holes, I used to use a charcoal briquet. Worked perfect and didn't have to waste my copper or brass.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #13
Hmmm... interesting. But why charcoal?
As far as plugging the holes for esthetic reasons, you could clean the insides with a wire bottle brush, tape one side to dam it up and use some two epoxy to fill. Sand flush, prime and paint.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #14
Weld doesn't stick to charcoal. For a small frame hole no backing would really be needed. We also used to use round charcoal "sticks" to repair elongated holes to make them round again. Stick one in the elongated hole and weld around it, Grind it down, no longer elongated. Or even to fix broken screw holes in aluminum motorcycle cases. Stick the carbon in the threaded hole and weld around it, chase the threads and done. Charcoal is great for those things. I have a bunch of different sizes of charcoal sticks, metric too.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #15
Years ago there was an outfit selling “kits” containing an assortment of different diameter carbon rods especially designed for fixing elongated holes in drawbars and implement hitches.
Maybe the kit had carbon backing plates also. Not certain as I was too cheap to buy it.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #16
I've sold the kits way back in the 90's. I used to do a ton of aluminum case repair for the cycle shops in my area. small carbons were a must. I have a bunch of Metric ones left if anyone wants them. They can be sanded down easily to fit and they are pretty hard and dense. Fun stuff.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #17
We are talking about a 51 year old truck frame with no visible crack issues on the frame in the area of holes drilled many, many years ago. Why fuss with it?
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #18
It is an appearance thing,,, USE JB WELD epoxy,,, :thumbsup:
It's had a lot of years with no weight so now it matters. Has no bed on it now so opportunity knocks.
Just a strength thing. I would agree JB Weld makes lots of things look better.
   / Is it OK to weld closed some drilled holes in my 1960's truck frame? #20
I believe welding will actually weaken the frame. At least do some research before wading in.
2016 Mitsubishi Outlander SUV (A55853)
2016 Mitsubishi...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55314)
Kuhns AE10 Small...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
