aftermarket starter and solenoid for Lx 172, Kawasaki 14hp
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #1
hslogger
western oregon
currently l4400 stick
I need a new starter assembly for my old mower. Bendix spring is shot, ditto solenoid.
Anyone have suggestions and good review for aftermarket or rebuilds?
thanks
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #2
It seems unusual that you would have two failures at the same time. What happens when you connect the battery positive terminal to the stud coming out of the starter, not the solenoid?
starter spins, gear doesn't rise up to engage.
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #4
OK now we are getting somewhere.
Try this next, jumper the battery positive to the large terminal on the starter solenoid, then use a smaller wire to connect the small terminal on the solenoid to the positive wire connected to the large terminal of the solenoid.
Lets see what happens.
Richard
I got no action what so ever
Richard
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #6
So based on your investigation, I would say that you indeed need a new solenoid. Now I don't know the price of just the solenoid vs the price of a totally new starter difference is. Look around and see what is available and the cost.
Good luck,
Richard
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #7
Richard could be right on here. If you Google the Denso number on the solenoid, it is quite easy to get them much more affordably than from Deere.
I bought a new solenoid on Ebay and it came, I installed it and it didn't work worth a hoot, and the install mechanism, ie a nylon finger was difficult. I pitched it and bought a new starter with solenoid from Jacks Small engines. installed it and starts like it should. I have had good luck with Jacks and E replacements over the years and reckon I should have done that to begin with. I will save my old starter and if the day comes I can find someone to go through it I might. Thanks for your inputs.
John Deere 7430 (A50120)
John Deere 7430...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
(7) John Deere Weights (A50121)
(7) John Deere...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A50323)
2007 Kenworth T800...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
