Looking at Used Nortrac/Jinma 304
   / Looking at Used Nortrac/Jinma 304 #11
It looks like it has been stored indoors, which is a good start. Overall looks cleaner than my tractor. The only thing that jumps out at me from the pictures is that the 3-point lift arms are all the way up, some owners have reported that the arms can get stuck in the up position. Make sure they go up and down when you operate the lever (you don't even need the engine on to get them to go down).
Most contemporary tractors have HST transmissions coupled with independent PTOs.
Gotcha.
Good to know. Should those typically bleed down after being parked like a FEL?
   / Looking at Used Nortrac/Jinma 304 #13
They shouldn't bleed down, that's an indication of a leaking cylinder, although if it's slow leak it's no big deal. What I meant is that if you operate the lever with the power off the arms will drop because dropping takes no power. I just think it's strange to have the lift arms up in the air like that. Normally, I use an attachment, and when I go to take it off I lower the lift arms and leave them down until the next time I need to use an attachment, at which point I want them down to hook up the new attachment. So I'd never drive around with my arms up like that. It could be perfectly innocent, but it's something to check since others have reported getting the arms stuck in the raised position.
   / Looking at Used Nortrac/Jinma 304 #14
Concerning the Live PTO - Nothing to really worry about , As an example running a brush cutter
Push the clutch half way in while tractor is in gear and PTO is running tractor comes to a stop but the mower keeps spinning
Push the clutch all the way in and the also pto quits spinning.
Much preferable to a transmission driven (Non Live) pto like some grey market Japanese tractors...
10-4
Gotcha, that's what I was thinking. Thanks.
   / Looking at Used Nortrac/Jinma 304 #16
Looking for a first tractor and stumbled across a 1996 Nortrac 304 with 579 hours and a Great Bend 240 FL for $6500. What's the consensus on these? I'll be using this for a 12 acre homestead doing mowing/plowing etc. I have no problem turning wrenches when needed, but it would be nice if it wasn't required on a weekly basis. What other tractors does this compare to for size and power?
Depends on how you define contemporary -
contemporary - living or occurring at the same time
This tractor was built before HST became as common as it is today in stripped down basic tractors. This tractor is selling for $6.5K. For example my M4700 built until 1998 wasn't even offered in HST.
OP - since you can wrench it looks like a viable first choice. Check all the hoses!
   / Looking at Used Nortrac/Jinma 304 #19
Since you don't put in your location it's almost useless discussing price on low price tractors. Those last two are almost 900 miles apart. Do you drive by either on your commute? It's not Amazon prime with free delivery and easy return if your not satisfied.
Are you willing to pay $7K for a tractor and take a day or two to pick it up? And get there and find "runs great" is correct, but "hydraulics leaking like a sieve" wasn't mentioned. Or do you need to trust it being delivered in perfect condition? Not every tractor seller discloses the bad info.
What goes for $5K in rural Mississippi can easily go for $7K in the Washington DC area.
   / Looking at Used Nortrac/Jinma 304 #20
Jinmas have live PTO and a two-stage clutch.
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
NEW Wolverine Skid...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
