pto grinding
   / pto grinding #1
snikers01
Member
2003 new holland tc 33
I have a 03 tc33 tractor, i try to shift to mid mound pto it grinds. there is not adjustment on the lever what is the cure?
   / pto grinding #2
I am assuming you have a gear drive (9 speed) tractor which has a 2 position clutch. Half way down stops forward motion and fully depressed disengages the pto(s). It is possible for the pto clutch to be rusted or stuck to the plate and not disengaging (lack of use). A possible cure would be to attach a pto driven implement (rear or mid), engage the pto with the tractor OFF. depress the clutch fully and start the tractor. You will probably have to override the safety circuits with a jumper to start with the pto engaged. good luck!
   / pto grinding
I have a hydro trans this would be my mid mount PTO
   / pto grinding #4
Not to be condescending, you are depressing the clutch petal before you engage the PTO lever?
   / pto grinding
yes even if I hold it in for a few seconds still grinds
   / pto grinding #6
Another similar posting said: "The screw that is a stop for the clutch pedal had worked it way out not letting me push the clutch in all the way. Screwed it in some more and now works great."
   / pto grinding #7
To the OP....If you are in gear and the hydro peddle is being pressed so you are moving, will your clutch peddle stop your movement?
   / pto grinding
Yes it will stop me it works "normal" in every other respect.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
CAT 312C (A50854)
CAT 312C (A50854)
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
