Rent vs buy
   / Rent vs buy #11
Are you talking about renting a 3PTH auger or hand held? Is your purchase consideration hand held or 3PTH?
I have tried using a hand held and will never go that route again!
For $350 I would buy a 3PTH auger (not a hand held though). You can then drill holes whenever you have a little time, save the trips back and forth to town and have it for future jobs. Maybe even drill some holes for neighbors and charge them a few $ per hole. It might pay for itself.
   / Rent vs buy #12
I realize you're talking about hand-arm-abs-back-and-shoulder(-and-maybe-face)-held augers, but I had a few holes to dig, along with an expected ~100 over the next few years... so I bought a 3ph auger for my tractor.
It's kinda heavy to setup by myself (I need to rig up one of those hangers like I've seen here!) but even if I only need to dig one hole, I can slap it and get the hole dug in next to no time, way easier than digging by hand in the hard pan clay we get here in the summer - I'd never rent for one or two holes, and having my own auger lets me get my jobs done when I want to do them.
   / Rent vs buy #13
Harbor Freight's is $214. I think I've seen it for less than that in an ad that I have at home. I'll check later this evening.
With that said... your soil is pretty soft, isn't it? I've got a hand operated post hole digger I use pretty often. I've seen them at Ace Hardware on the south side for less than $50. Burried a lot of pets with it, too. Goes through our sand and muck in a hurry.
Pay a kid $25 to dig your holes. :laughing:
   / Rent vs buy #15
I wouldn't rent or buy a handheld power auger like this below. It's tractor powered pto or hydraulic only.
   / Rent vs buy #16
I prefer to buy as I know I will most likely use it again and it always seems that friends turn up unexpectedly on project days which is a waste of rental money, I bought an auger and later we found that we needed a lot of posts put in so it was a win for me, this is a PTO auger and a contractor would have cost us a lot more.
Storage is not an issue and it sits in the corner of a carport, they are pretty much weatherproof although I have a cover over the gearbox.
Like others depends on what you want to rent and a skid steer or something similar would be a rental, my own ceiling is $1k.
   / Rent vs buy #17
I need to plant some 6 inch round wood posts. Some now and some in the spring. No I cannot do them all at the same time.
Renting a powered auger cost is around $70 for the day. Cost of buying is around $350 when you get all in with the bit needed etc. assuming harbor freight purchase.
Where does one draw the line of rent Vs buy? I am approaching half the cost in just two rentals.
Pretty sure I would NOT sell the tool after my projects are done. I tend to hold on to things.
you aren't the only one that struggles with purchase vs rent.
I needed a good drill to be able to install several T in rock.
I rented one for $125.00 per day. So, I rented it for a day.
While using the drill it began to rain and rained the rest of the day. I was only able to drill two holes for $125.00.
I decided this wasn't going to happen again. So I bought the drill.
Now I can use it when I want and don't have to drive .45 min each way to pick up and return.
https://www.homedepot.com/p/Makita-...Hammer-Drill-with-Hard-Case-HR5212C/205650381
   / Rent vs buy #18
I helped a friend with his hand held - two man - auger. What a joke. The auger would hang up on something and around the maypole we would go.
COULD NOT figure out why we were having so much problems with this auger. Well - idiot child( the owner) didn't like the position of the throttle - so he rotated it around the handle to the upstream side. When the thing would hang up on something - around and around - thing going full bore - idiot child hanging on for dear life - because the throttle is on the upstream side - his gripping the handle meant the throttle was being held wide open.
You know - all in all - that was not a real fun day.
   / Rent vs buy #19
LOL I watched a couple of guys give it a whirl not long ago, No good..
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A51242)
2014 JOHN DEERE...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
