Fuel Shutoff Solenoid ? 2210 dies with no warning.
   / Fuel Shutoff Solenoid ? 2210 dies with no warning. #11
I have a JD 4600 and have had problems with the fuel shutoff solenoid. Looking at the exploded diagram for the 2210, it looks like a very similar solenoid, possibly even the same one. In my case it was the infamous thermistor that failed, so initially I would have an intermittent start and eventually I couldn't get it going at all. With the 4600, the fuel solenoid is spring loaded so it is normally extended, then when energized, it retracts. So in my case, I could simply remove the solenoid and it started right up. The problem was, with no solenoid in there, there was no way to shut the tractor off. So temporarily, I could reach in there with a finger and press the tab that the solenoid pushed on to shut it down. With the solenoid out, I always get a small drip of oil leaking out of the opening while the engine is running. That solenoid is fairly inexpensive on ebay, so in my case, I hacked into it and removed the spring. Then I attached a small pushrod to the end of the shaft with an epoxy seal so I could push it in by hand whenever I want to shut down the engine. I actually ran the tractor like this for several weeks until I figured out that it was the thermister causing the problem. I eventually replaced the thermister with a pushbutton switch and it has run great now for a couple years. I have a thread here on tractorbynet where I described that in detail.
With all that said, if it's easy to pop your solenoid out - it should be held in by two bolts - then do so, and if the engine runs fine, you've at least isolated it to being related to the solenoid.
   / Fuel Shutoff Solenoid ? 2210 dies with no warning. #12
Diodes do NOT go intermittent. it's impossible, so rule that out, and save a few good bucks!. $13 a piece is a rip too.. I'd say either the solenoid is failing, or the voltage going to it is failing intermittently.. you may just have corroded connections somewhere causing this..
So here's the update... I've replaced the 3 visible Diodes, and bypassed the seat sensor. Mowed for hours, up & down hills, round & round. Tractor never faltered.
Dealer says the 2210 shows no listing for a Thermistor in the parts listing or diagrams, they don't believe this tractor has a Thermistor (although they showed one for the 4000 series tractors). I haven't had time to pull the dash panel to search for it. My theory is that either the Solenoid is beginning to fail (in which case this problem will become more recurrent), or that one of the diodes was not making good consistent contact. By replacing them, that has been remedied. As I use tractor this fall for leaf pickup, and then for snow removal, I guess I'll see if the problem comes back. Thank you everyone for your suggestions and help. I'll keep you posted if it reoccurs.
   / Fuel Shutoff Solenoid ? 2210 dies with no warning. #14
You may have fixed it replacing the diodes, I hope you did and it doesn't give you problems when it's cold and snowing.. My stuff doesn't seem to break when it's nice and warm, it waits til I can't feel my fingers on a wrench..:laughing:
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Pickup Instructions (A55272)
Pickup...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
CLAYS 6' X 10' S/A TRAILER (A52708)
CLAYS 6' X 10' S/A...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
