Hauling firewood on a landscape utility trailer
   / Hauling firewood on a landscape utility trailer #51
Post #48 you figure that is a max load for the trailer?? WoW - my wood trailer must have been WAY overloaded. Same sized trailer but with five foot high sides - loaded and stacked to at least a foot higher than the five foot side racks. Thank God we only moved it on our own property.
He only has a 7 k trailer. I’d guess he had more than 7 k on it. It was soft maple at least in the top so it’s not very heavy but that’s still a lot of wood.
   / Hauling firewood on a landscape utility trailer #52
He only has a 7 k trailer. I壇 guess he had more than 7 k on it. It was soft maple at least in the top so it痴 not very heavy but that痴 still a lot of wood.
Legal net weight for a 7K trailer is in the 5000-5400 range. The pictured load is well within that, I bet.
   / Hauling firewood on a landscape utility trailer #53
4570man - Are we both looking at the same trailer load of wood. Post #48 - single layer of wood in that trailer - - its going to weigh 7000 pounds?? This is a pic of my poor 'ol wood trailer - - 6'wide by 12'long with 5' high sides. If we stacked the green split pine tight and high - two cords.
   / Hauling firewood on a landscape utility trailer #54
Legal tare weight for a 7K trailer is in the 5000-5400 range. The pictured load is well within that, I bet.
tare weight noun
Definition of tare weight
: the officially accepted weight of an empty car, vehicle, or container that when subtracted from gross weight yields the net weight of cargo or shipment upon which charges can be calculated.
Legal tare?
   / Hauling firewood on a landscape utility trailer #55
Sorry no. I was confusing post 40 with the OP. Even being maple I’d guess the load in post 40 is over 7k. I doubt the op in post 48 had over a ton of wood.
I was playing it conservative, as it was the first time I was hauling firewood on that trailer and I was going to be driving 70 miles at an average of 55mph. But yeah, I figure by the numbers I was approaching the limit.
Here's how I'm coming to that conclusion:
- I'd say 95% or more of that load is red oak, and a handful of hickory logs mixed in that the oak took down. From what I'm reading, a cord of red oak can weigh anywhere from 4700-5700#, depending on if it's dry, seasoned, green, wet, etc.. This wood came down a little over a year ago. It's also been a very wet year and the outer area around the bark was fairly wet, centers were very hard and dry. Let's just say 5000#.
- A cord is 4x4x8, or 128 square feet. Granted those logs aren't split real small, so there's a lot of air space in there. But given my trailer is 16' long and 6.4' wide, that means a cord would be if I stacked the wood 1.25' high in my trailer. It's stacked right around that height in the back, and a little lower toward the front.
- My trailer is a 7000# trailer and weighs 1740#, which means I should be able to load 5260#.
I feel confident I could have loaded more, but given the distance, I wanted to play it safe.
The tires didn't look bad with that load on there, and the truck didn't sag much. The Tundra pulled it great. Except going up some steep hills out of river valleys, you could hardly tell it was back there. It was a joy to drive.
   / Hauling firewood on a landscape utility trailer #57
Whew - OK - post #40 - that's more like it. Lordy - I was looking at that single layer and wondering 7K ??? My God - you would need a gantry crane just to pick each chunk out of the trailer. I just checked and a green chord of pine is going to weigh right around 4400 pounds - and we were able to get two chord in my old wood trailer. No wonder is pulled so hard. My poor little Ford 1710 had to work like a whipped mule to pull a loaded trailer half a mile. And we would get four loads every fall - we burned wood for twelve years here.
   / Hauling firewood on a landscape utility trailer #58
That should be nearly 3 cords. A cord is 4x4x8-128 cubic feet. The trailer is 360 cubic feet.
   / Hauling firewood on a landscape utility trailer #59
tare weight noun
Legal tare?
Sorry. Net weight.
Definitely had well over a ton. Based on the numbers I don't see how it could have possibly had less than two ton, unless the cord weights I'm finding online are very wrong.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
New Wolverine Push Blade (A53002)
New Wolverine Push...
