danged if I can figure out what to call it.
   / danged if I can figure out what to call it. #11
   / danged if I can figure out what to call it. #12
I think I'd be looking for a heavy duty box blade or roll over blade and torch what's not needed off
something like this can be found on Craigslist and such
https://www.tractorbynet.com/forums...ets-see-your-modified-box-gill5-5boxblade-jpg
I was thinking box blade w/scarifiers too... and just tilt up all the way and drop the scarifiers to max depth. I just bought a used box blade and thinking that is what I would do. A box blade if you can get the depth you need, would be a far more versatile tool in my opinion.
   / danged if I can figure out what to call it. #13
I've got a ballast-roller with spiked 'bands' to aerate my ground.
   / danged if I can figure out what to call it. #14
if you're just wanting to 'aerate' that's typically just poking holes, so one of the rollers with spikes would do that fine. If you want a bit bigger hole, get one with tubes that will pull plugs out will do what you want. A scarifier or box blade with the scarifiers lowered is going to really tear up the ground, if I was going to that extreme, I'd just use a disk harrow.....
   / danged if I can figure out what to call it. #15
do you need a box blade? Buy one with scarifiers. If you already have a box blade sell it and buy a new one.
you can probably buy the teeth from EA and make your own.
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
