Hauling firewood on a landscape utility trailer
   / Hauling firewood on a landscape utility trailer #61
Yes - it should have been real close to three chord - and maybe some loads were. I know when she was stomped full - every bump or swale would cause the trailer to rare back and lift the poor little Ford rear end completely off the ground. Thank God for good tight ball hitches - never once lost the trailer but we were going about 1.5 mph MAX and only had to go about half a mile to the wood shed in the yard.
Man - those were the days - 1982 thru 1996 - harvesting, seasoning and burning wood. It was all great - EXCEPT for the dirt and bugs that the firewood brought in the house.
   / Hauling firewood on a landscape utility trailer #62
I just picked up 7 PU loads of dry oak and elm...good heavy stuff. The loads were moderatly heaped and the 2013 Sierra 4x4 RCLB squatted pretty good. I had been thinking about a equipment trailer to haul wood and the toolcat, but after seeing this thread, I need some sides. I see PJ has a 10k UT with removable sides that might work. At least the 7 loads with the truck were only about 6mi each way.
   / Hauling firewood on a landscape utility trailer #63
The only "hard wood" I've ever had here were the apple trees in the orchard. I pulled the last of them this year. I noticed, quite easily, that a 6" diameter apple trunk is considerably heavier than any 6" pine. I can well imagine that a load of oak would make a pickup settle right down.
Down the road there is a "grove" of locust. Its at an old homestead site. I cut, seasoned and burned half a chord of that stuff back when I was burning wood. Nice, heavy stuff - burned forever in the wood stove. Excellent for "last log of the evening" when you are going to bed.
   / Hauling firewood on a landscape utility trailer #64
You travel 70mi one way for a single cord of wood? Gesus i would be burning oil if i had to do that.
Oak takes almost 3 years to properly dry. Split it and let it sit covered. Few weeks ago i cut and split white oak logs that were in a pile of oak/maple for 3 yrs. All the maple was junk and the moisture content of the oak was still 30* not even close to burnable.
   / Hauling firewood on a landscape utility trailer #65
Same here. I got paid 150 to haul off probably 5 cords of logs and it was 17 miles each way. I hated every second of it. There’s have to be something a lot better in the table before a hauled a cord 70 miles.
   / Hauling firewood on a landscape utility trailer #66
That would be about $25. I think the math would still be on the side on a cord of wood assuming no additional outlay is needed other than consumables.
   / Hauling firewood on a landscape utility trailer #67
That would cost me 43 dollars in fuel round trip assuming 10 mpg and it’s between 2-4 hours round trip.
   / Hauling firewood on a landscape utility trailer #68
That would cost me 43 dollars in fuel round trip assuming 10 mph and it’s between 2-4 hours round trip.
Maybe drive a little faster? :D
   / Hauling firewood on a landscape utility trailer #69
An hour each way is the absolute best you could do while maintaining a legal speed unless you live out west. No running 70 from your house to the load point isn’t going to happen so I’m figuring 3 hours drive time.
   / Hauling firewood on a landscape utility trailer #70
You will need 7 hours each way at your 10mph :D
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
Kubota BX2230D (A47384)
Kubota BX2230D...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
