Switch Activated Seat Safety Cutoff (2032R)
   / Switch Activated Seat Safety Cutoff (2032R) #1
mikefd
Member
NY
John Deere 2032R
I like my seat safety, sometimes. I think it's an essential safety feature, but it's also annoying. I didn't want to get rid of it entirely, because if I'm brush hogging and I roll the tractor, I don't want to get shredded by the rotary cutter. But, most of the time, I don't want a seat safety.
So rather than disable it, I rigged a switch to turn it on and off on demand:
   / Switch Activated Seat Safety Cutoff (2032R) #2
There are times when the seat switch becomes a nuisance. I was particularly amused with the switch labels!
   / Switch Activated Seat Safety Cutoff (2032R) #3
A thought about safety, maybe it should also have pilot/warning lamp for when seat safety is bypassed...
Dale
Dale
Yeah, that's the plan, when I find a good illuminated rocker switch.
   / Switch Activated Seat Safety Cutoff (2032R) #5
If anything ever happens where your attention to and the importance of safety is ever questioned in court . Your advice and video will hang yourself .
You mean I won't be able to sue myself if I get killed because the tractor is still running? I will try to live with it.
   / Switch Activated Seat Safety Cutoff (2032R) #7
:thumbsup:
I have done somewhat the same, with a switch which will force the tractor to start (turn over) and a switch to disable the safety gear when running. Normally these switches are off and located in a covered box, so that all the safety stuff works as designed.
This has been a pet peeve of mine for years. Before retiring, we farmed and start problems because of safety switch malfunctions was a real problem. If the manufacturers of these machines feel that these designs are so necessary, then the engineering solutions should be almost bullet proof, and one of the last things to malfunction. To do otherwise invites the owners to do as documented here and above.
   / Switch Activated Seat Safety Cutoff (2032R) #8
Someone trying to rescue you could certainly sue you.
   / Switch Activated Seat Safety Cutoff (2032R) #9
:thumbsup:
Manufactures have been sued since that woman laid the fuel cap/fuel gauge over the battery terminals on a JD 110 garden tractor . Manufactures have to worry more about lawyers than the owners .
   / Switch Activated Seat Safety Cutoff (2032R) #10
my GT is disabled too. I always turn off the pto if I am mowing when i stop. but damned if i am going to wear out the starter every time i find a dog toy to move out of my way!
43013 (A51691)
43013 (A51691)
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Caterpillar 304 ECR (A50120)
Caterpillar 304...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
