I have 4 broken bolts on my tractor.
10.9 - 20x90 bolts, broken off about 1/4" below the frame surface.
I drilled one out before and replaced it. Drilling it with a hand drill and time + frustration. But I was able to remove it without anything more than sweat.
I have a compact mag drill now, which can get to 2 of the bolts as is and the other 2 after these are removed and the loader frame is reattached.
So... on to my idiocy and issues.
I drilled out one without incident. Removal was straightforward.
I moved to the second, and put in the same size reverse removal tool, and snapped it off in the hole. So now, I have hardened tool steel inside the center of a hole of the bolt. Admittedly, I cut a corner and used only a 1/4" remover, as it worked on the other 2 bolts I have used. I know I should have taken the time and enlarged the hole for the larger remover, but that is only history and lesson learned.
So now, I need to remove the bolt, with a tool steel center which I cannot drill out with my mag drill, as I only have HSS bits. I cannot find a 3/4" Weldon shank drill bit in Carbide. Annular cutter won't work, I don't believe as it will leave the plug in the hole, thereby, I can't insert the removal tool. HOWEVER, I was wondering whether I could perhaps use an annular cutter and cut completely through the end of the bolt, into the end of the hole within the frame, thereby allowing the plug to be removed. I don't have an annular cutter that small, so 1st, if this is a possibility, I'd need to get a couple of cutters in order to cut deep enough with the shorter cutter, then put on a longer cutter, to allow for the short throw of my compact mag drill. The throw is about 1 1/2" and the bolt begins about 1/4" down in the hole.
Regardless, I need help.
I need either the smallest diameter annular cutter with 3/4" weldon shank, available (small enough to go down the length of a 20mm bolt with room to spare for inaccuracies) or I need a 1/4-1/2" carbide bit on a 3/4" weldon shank with lengths 1" and 2" in order to make it work.
So, if you have a good source for good quality bits like these, I'd appreciate the connection.
Carbide
Weldon shank 3/4"
- 1/4-1/2" dia - 1" and 2" lengths
Weldon shank 3/4"
- Annular cutter (smallest diameter available)
- 1" and perhaps 2 1/2" length cutting depth. ???
Any thoughts would be greatly appreciated.
