ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,450
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
Try this if you haven't already - remove the mower and raise the hitch fully with the control lever. Then go back and grab one of the lift arms at the ball end and lift it until you come to the stop. If it goes up more than an inch that says to me that you are not getting full height and need to adjust your lever linkage or your feed back rod.
gg
^^^agree^^^ That is a good test to check if the lift arms attach to the rock shaft has been changed. If when lifted by hand (to the top limit), compare that to a unit that is known to be original. Remember to use measurements from the non-adjustable side.
