JD6800 front wheel lock up on 4wd tractor
   / JD6800 front wheel lock up on 4wd tractor #1
tobac
Victoria
John Deere X595, M
A friend has a JD6800 that he was using on a round baler. All of a sudden when turning right the left front wheel would lock up and then let go. This continued. When driven straight it was OK. Oil levels were checked for metal. One was low and the other had some metal on plug but not excessive. The tractor was jacked up. The bearings felt good with no noise when steering straight or on turning. Universal joint looked good. No oil leaks. The hub pivot bearings seemed tight with no play. We are at a loss where to look next. Next stop may be to look at the drop down box in the transmission. Could the bush that is located in the front end housing have picked up on the axle? If anyone has any suggestions they would be appreciated. Thanks.
   / JD6800 front wheel lock up on 4wd tractor #2
I think the cage locating the balls in a bearing for the left wheel, or its drive mechanism, has failed. In this condition weight/stress can cause the balls to bunch and jam the bearing or any gears that may rely on it for an accurate pivot.
   / JD6800 front wheel lock up on 4wd tractor #3
Welcome to TBN
Have your friend jacked up frt wheel then rotated it to listen for noises?
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
vergenes (A50657)
vergenes (A50657)
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
