plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,046
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm building a new residence in Northern Nevada. Framing is done, windows in, most exterior doors installed, stucco lathing done. Almost ready for drywall. Lots of square footage and some 10' and 12' ceiling heights. Insulation is starting to be installed today.
Drywall installers say they need the house at 64 degrees or higher for drywall install and mud. They have three 50amp portable electric heaters-- one could go in the basement, two on main level. So far, so good.
I asked how long they need to run those heaters. Their response: until April! That's about 5 months of continuous electric heat, which I know is very expensive. Aaahhh. They say they don't want the house cooling down then heating up. Overnight temps over the winter are usually in the 20s, but I've seen it as low as 1F.
My furnace contractor said if I instead run the propane furnaces (three) it will void the warranty. Those cannot be run "during construction" as the fine dust and debris will damage them not to mention coating all of the ducting. I have not yet set the propane tank for those heaters, but I could if needed. The propane lines are run and the heaters are in.
I'm presuming the electric heaters would cost thousands of dollars to run for 5 months. I've never heard of keeping the heat up for that long. Is that typical for drywall?
