Check Your Roof Vents for Leaks!
   / Check Your Roof Vents for Leaks! #1
Beltzington
Appling, Georgia
JD 3720
I am remolding a bathroom and after tearing down the drywall I found some dry rot on the top framing plate where the sink vent goes through the ceiling. Got up onto the roof and found five of the six vent boots have dry rotted which allows water to run down the pipe. My roof is less than 10-years old with 40-year shingles but apparently the cheapest boots the contractor could find. It always amazes me where construction companies decide to save (make) money.
Perma-Boot manufactures a vent repair boot that goes over the existing vent without having to remove shingles. Seems to work great and has a lifetime warranty against rot.
   / Check Your Roof Vents for Leaks! #2
Looks like a bad batch of boot material. Bummer it happened and glad it was caught before too much damage.
   / Check Your Roof Vents for Leaks! #3
looks like hail damage
No just UV damage of cheap material, we have not had any significan't hail since the hail damage that got me a new roof. Georgia summer sun can be brutal, and unfortunately the roof gets very little shade.
   / Check Your Roof Vents for Leaks! #5
Our boots started leaking after 15 years. We could have got a few more years out of the shingles but the roof was turning dark with streaking so we replaced the entire roof. The problem is, it looks like the same type of boot was used again. Hope i'm wrong.
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
Dual Cylinder Grapple Skid Steer Attachment (A51691)
Dual Cylinder...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
