mystery problem with kubota la524
   / mystery problem with kubota la524 #1
grego
Downsville NY
New Holland tc33d
This Kubota, only 160 hours on it, has a problem with the loader. Lifting or lowering it moves extremely slow. On float, it lowers quickly. Curl works fine in both directions. When attempting to lift, engaging a bit of curl allows it to raise quickly.
Pulled the spools, all looks new and clean as I expected. Any ideas? Help appreciated.
   / mystery problem with kubota la524 #2
Recheck your quick couplers!!!!!
Thanks Leejohn....Seemed ok when checked....
BUT!!!!Just found a youtube post with the exact same problem. IT'S THE 3 POINT LEVER!....Must be in the relaxed position.
all well now.
   / mystery problem with kubota la524 #4
Adjust your feed back adjustment and it well stop that.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
Electric Concrete Mixer (A51573)
Electric Concrete...
Hay Spear for Tractor (A51573)
Hay Spear for...
